Results 1 to 4 of 4
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Angry Power Seat Groans when I try to go up
    More issues this winter than I need...
    Anyway, my driver's side seat's motor doesn't go up as far as it used to when I want to tilt the front part up. Once, it got stuck on the low height setting until I tugged up on the front and pressed the switch to go up, but it still has a limit less than what it should be.
    Any thoughts? I am suspecting the motor may be on it's way out, but wondering if anyone else has dealt with this issue before as no results were found while searching.
    TIA
    Avanta-Humpa-Lot
    Account Terminated Four Rings
    Nov 18 2008
    Los Angeles, CA!!
    Re: Power Seat Groans when I try to go up
    lose weight? hha im just kidding.
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    might be time to look for a new seat, theres gotta be a few on the cheap from junk yards etc.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    May 30 2007
    Garage no more :-(
    'sconsin
    Quote Originally Posted by ghosta4 View Post
    Bastid!
    Actually I think it has to do with the motor because it works, but not correctly on the up swing. It's original and I have a CPO for another few months. It should be covered right? I'll call to check anyway...
    Avanta-Humpa-Lot
