Results 1 to 16 of 16
    Senior Member Three Rings gaith's Avatar
    Sep 06 2007
    San Francisco Bay Area
    Gearbox oil leakage from a freakin plastic bag!
    Driving back from a nice vacation, I drove over an empty black plastic bag on the highway and i did not think twice about it.
    A few days later, i started hearing a weird rattling sound coming from the gearbox area.
    After taking it to my local garage: the damn plastic bag was stuck between the end of the gearbox and the rear shaft (Quattro). God knows how many thousands of rev its went thru!
    After removing it, we are now getting some gearbox oil leakage from that area. we obviously damaged the radial shaft seal.
    Where can i get diagrams/schematics (those exploded views with all the parts and their numbers) of the gearbox so i can figure out the part number?
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    Re: Gearbox oil leakage from a freakin plastic bag!
    go under differential on ECStuning.com and they sell the seal there
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Sep 06 2007
    What is the name of that seal, since they list several different ones?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by gaith View Post
    ...Where can i get diagrams/schematics (those exploded views with all the parts and their numbers) of the gearbox so i can figure out the part number?
    Not sure if u are man/auto trans I'm @ wk but I can find what u need when I get home & post up a parts break down for u if that will help and no one else does it 1st
    Oh and for the record I always look in my rear view for stuff I run over... Like Indiana Jones "I hate plastic bags on the street" ... most likely u do too now.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Sep 06 2007
    Thanks... It's auto transmission.
    May 13 2008
    NoCal - EBay
    Not sure this is what u need. I'll look some more - lemmie know if its not the right parts diagram or ???
    So far digging around the program leads me here: Audi A4 B6 5-spd automatic transmission
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    i think its # 31 in the second picture
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
    Jan 24 2007
    Quote Originally Posted by rocketheavy View Post
    #31 seems like prop shaft seal
    Sep 06 2007
    thank A4SoftWalker..... this looks like the proper diagram.....
    Sep 06 2007
    so i searched ECS tuning for #31 using part number: 01V 409 399, and nothing turned up.
    but under 'remarks', it states 'also use: 01V 409 809', corresponding to #32 on the diagram, which look to me as a completely different part!
    searching ECS tuning for the '01V 409 809' turns up ' Original Equipment Supplier - Drive Axle Seal-Right (Passenger) Side ES#5813, Output shaft seal on front driveshaft flanges'
    i am confused, whats going on here? any help would be greatly appreciated.
    May 13 2008
    NoCal - EBay
    Ur welcome, Thought u were done with this & just never returned to report back, seems like forever now... Are u sure u included the "A" @ the end of the part number well I ran the search and came up with this
    Looks like that is the part to me. No pic but the description fits.
    but under 'remarks', it states 'also use: 01V 490 809', corresponding to #32 on the diagram, which look to me as a completely different part!
    searching ECS tuning for the '01V 490 809' turns up ' Original Equipment Supplier - Drive Axle Seal-Right (Passenger) Side ES#5813, Output shaft seal on front driveshaft flanges'
    The ETKA is not user friendly and is actually meant for Audi/VW techs which I am not but my understanding is that "also use" means to consider using it when the other part is affected. Now the flange shaft leads to the drive shaft and that is highly ulikely to break but my guess is if u take it apart u will need the new ECS gasket above for longevity unless u want to fix another leak soon. Hope that does it for u.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Sep 06 2007
    so here is the weird thing...... searching ECS tuning for the EXACT part number turns up nothing on my end!!!!!!!!!!
    so i contact them by email, and they have the flange but NOT the oil seal!
    trying to find it online without any luck. Other than ECS tuning, what are my options?
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    www.genuineaudiparts.com and search the part number
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
    Sep 06 2007
    thanks....
    so they have the shaft in stock, plus its $76 cheaper than ECS!.
    as for the oil seal, they have a part number 01V409399A with a description of 'seal', and not b 01V409399A. Do you think the b makes it a different part? or shall i go ahead and buy it!
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    its probably just a revision
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
    Sep 06 2007
    Parts fit perfectly... All is good... Problem fixed
