Results 1 to 6 of 6
    Dec 26 2008
    yay
    whistling in cabin when fan is on
    hey guys, new to forums
    what causes the loud whistling noise near passenger side vent when the fan is on? the whistling goes away when fan is off
    thanks
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    Re: whistling in cabin when fan is on
    could be a bad fan. maybe one of the blades is chipped or cracked or busted. that would explain some whistling.
    B7 RS4...mmmm.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    hitting/grazing the bi-pipe?
    B5 S4 AWE Stage 3 - sold
    Dec 26 2008
    yay
    i was told it might possibly be the pollen filter? is this a possibility? how much for this part and how hard is it to replace?
    thanks for the input guys!
    Nov 23 2007
    Columbus, OH
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    if it happens when you're heat is on, it may be the blower motor that's behind the glovebox. Mine used to squeak while the heat is on, and oddly enough, when I would be turning left. I just took the motor out and sprayed some WD40 on it and the sound hasn't come back since.
