Results 1 to 7 of 7
    Feb 02 2008
    03 allroad 6MT, Turbo M3
    Downers Grove, IL
    anyway to reset the 402 ride height?
    i know the previous owner had lowerd my car but im not sure to what or any idea on what its set now. I just up'ed it to 395 in the front and 395 in the rear. I'd like to be able to start from scratch though to know where i am.
    So anyway to reset it?
    ///Andres
    03' allroad 6mt -black - 402'd, K&N, RS4 clutch, APR exhaust, RNS-E, H-Sports, HP-2, SS brake lines, 19" RS6, 35% tint
    95' M3 - custom turbo ~550+hp on base boost
    Veteran Member Four Rings Myallroad's Avatar
    Apr 11 2008
    Independence, KY
    Re: anyway to reset the 402 ride height?
    allroadfaq.com
    has instructions on how to reset. you need a vag to do it.
    10 S4 DSG Sport Diff B&O MMI
    18 Q5 2.0t PP BO VC
    Feb 02 2008
    Downers Grove, IL
    i didnt see any instructions on how to reset, just on how to change height, which i already did.
    ///Andres
    Apr 11 2008
    Independence, KY
    dont think there is a way to reset. correct me if i am wrong but 402 is the stock ride height. just follow the instructions to get it back to 402.
    18 Q5 2.0t PP BO VC
    Feb 02 2008
    Downers Grove, IL
    i take it just measuring from the center cap on the wheel to the fender lip? and change it till you get it right? that would be a pita, oh welll
    ///Andres
    Apr 11 2008
    Independence, KY
    sounds about right, yes it is a pita, but just set it to where you like it and you dont have to worry bout it.
    18 Q5 2.0t PP BO VC
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    No way to reset. You have to measure from the apex of the wheel well to the center of the wheel on level 2. Measurement should be 402mm. If not, compensate with VAG-COM what ever the difference is. Once the allroad is at 402mm on all four wheels while set at level 2, you are back at stock setting for height. Then do 402 mod to get the car to the height you personally like. Also, it is very important to park on a flat level surface when you do the measurements and height adjustments.
    Good luck
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
