Results 1 to 3 of 3
    Veteran Member Four Rings ray-ray's Avatar
    Jul 08 2004
    Moreno Valley, CA
    Help with Suspension
    here is some info on my set up right now: My current set up is neuspeed sport springs, running on stock sport suspension shocks. only have about 20k miles on the car, and i just put on some wheels VMR v710s, et35. tire is general exclaim 235/35/19 and i have some rubbing in the back.
    I noticed that the back looks like it sits a bit lower than the front. is that normal?
    also, i noticed some pics here when i searched h&r that it seems to be a bit higher than neuspeed sports. do neuspeeds tend to sag over time? Besides trimming the fender liner, will changing to springs like h&r help out? thanks.
    ps...i have searched already. merry xmas
    Old Car: 2003 Audi A4 1.8T Dolphin Grey with AWE GT28R Turbo Kit
    New Car: 2008 Audi A4 2.0T Quattro Ibis White, GIAC X-Flash from Torque Factory
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: Help with Suspension
    Well my friend, H&R springs are supposed to drop 1.7F / 1.6R while Neuspeed springs are supposed to drop 2.0F / 2.0R. Neither spring should ever sag.
    While Neuspeed is lower than H&R, Neuspeed is also known for having a little reverse rake so that is normal that your rear is a tad lower.
    As for rubbing, check to see if there is a torx screw at the edge of the wheel well at the very top. I forgot if there is one back there (there is on the front) but remove that first to see if it fixes rubbing. I know other people are running similar setups so we'll see how they fixed rubbing issues before I start suggesting things
    Ignorance is bliss.
    Jul 08 2004
    Moreno Valley, CA
    Quote Originally Posted by Phrost View Post
    there is no screw in the back like there is one in the front when i checked earlier today. Also as far as ride drop, i am running the neuspeed sports, which drop 1.5f/1.5r from stock suspension (non sport), which is less of a drop than h&r on paper. funny thing is that it i do have the reverse rake you talk about, and it looks like i am running race springs at times...looks lower than normal. i'll take pics tomorrow and post them
