Results 1 to 12 of 12
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Chasing a Coolant Leak
    Alright guys I've done plenty of searching and was wondering if anyone could give me a bit of advice. I've got a small coolant leak (goes below the low indicator every 3-4 days) so I'm constantly topping off the reservoir. The only visual findings so far are of some white residue on top of the tranny and on the line right below the temp sensor, and I think it might be coming out of the coolant line back there. The only thing is whenever I pop the hood I have yet to actually see anything coming out of right there, but right now I don't know where else it could be coming from. Any good ideas on spotting a coolant leak? Like using some kind of a die or something in the coolant? Here are some pics of where I think it might be coming from.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Re: Chasing a Coolant Leak
    You sure its not from the CTS? The CTS has an oring, check to see if that oring is ripped.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Jun 24 2008
    E46 M3
    Woodinville WA
    replace the coolant flange and all associated seals. probably should get a new temp sensor as well as looks old and has likely already outlived it's life expectancy. Also they'll often times get damaged when trying to remove them as they get "stuck" in the flange. The coolant hose may be ok but pobably just easier to replace it while you'e already getting in thee
    C
    Oct 26 2006
    A lot of B5 S4's
    WA
    I'm like 90% sure thats what it is, but its been in the 20s and snowing so I've just been way to lazy to go pull it out real quick and check.
    Oct 26 2006
    A lot of B5 S4's
    WA
    Quote Originally Posted by Affinitive View Post
    C
    Stealership? Anyone got a P/N for that flange?
    Oct 26 2006
    A lot of B5 S4's
    WA
    Just found the write up for the flange on AW, I'll head out to the stealership tomorrow and pick one up along with a new sensor and hook it all up, I need to flush my coolant anyways. Here's a link to the write up as well if anyone needs it.
    http://www.audiworld.com/tech/eng76.shtml
    Jun 24 2008
    E46 M3
    Woodinville WA
    LOL
    No I'm not a stealership. But I do run and own a shop and worrk on mainly just Audi's. Going the route I recomended is what generally turns out to be needed and fixing it right to first go around.
    PLenty of online places should have all those parts but even with the dealer sucharge, everything should be petty cheap
    Good luck
    Jun 24 2008
    E46 M3
    Woodinville WA
    the r button on this new keyboard doesn't seem to work very well........sorry
    Oct 26 2006
    A lot of B5 S4's
    WA
    ^^ Ha sorry I didn't mean it like that I was just asking in general where to get it at, not intended towards you, no worries, and ya they are all pretty cheap parts. I would get them online but for a few bucks more I'll just get it fixed tomorrow as long as they have them in stock. Thanks!
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    as stated above, replace the coolant flange and the temp sender seal. fairly cheap parts.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Senior Member Two Rings itsbigj05's Avatar
    Nov 28 2007
    ducati 696 and mg midget
    Pittsburgh
    I know its a long shot, but does anybody know the part numbers for the o-rings, flange, and hose that goes to the heater core? I had a nasty leak from one of the o-rings, but the guy at the VW dealership gave me two of the wrong size rings (the CTS and stupid random plug were the right ones). That one hose is looking pretty beat, so I'm just going to replace it while I'm back there busting up my hands.
    Something always has to go wrong when money is tight, doesn't it?
    Nov 28 2007
    Pittsburgh
    Nevermind. I just ordered everything I need from ECS. I'm taking back those rip off $3 o-rings that I got from the dealer.
