Results 1 to 10 of 10
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Need Urgent Help
    So here's the short end since I'm posting from my blackberry
    1) Put on snowtires
    2) drove 100 miles
    3) car starts vibrating at around 60mph
    4) thought it was balance issue so took to dealership - ballanced but still problem
    5) they said no bent rims / significant bends
    what could it be? - its a wobble/vibration only when stepping on gas - when crusing no vibration
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Re: Need Urgent Help
    Engine mounts bushes!!
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Sep 13 2008
    Western Chicago Burbs
    My snow tires do the same thing at around 55mph when they are cold. when they warm up, the problem seems to go away. i have Bridgestone Blizzak LM25
    Mar 27 2005
    The Cold North
    if you park outside overnight it could be the temporary flat spotting on the tires from sitting. Does it go away after the tires warm up? if it doesn't go away after warming up you could have a tire or two out of round. if these are new tires i would go back to the place you bought them and get them checked.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Hubcentric Rings?
    Wheel Bolt torque problem? Make sure you torque them in the * (star) pattern.
    Loose belts in a tire?
    Go to AUDI and tell them to have them ROAD FORCED BALANCED. That machine works wonders! It should be $50 and it will give you a print out of tire wear, tire belt wear.
    It will even tell you to remove the tire from the rim, rotate it 180 degrees and re-install it to help balance it without weights!!! Pretty cool huh.
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Put the summer wheels/tires back on and road test to see if its still vibrating under load.
    If yes, then check your mounts. If no, then it's your tires --> road force balance.
    Anytime I get any kind of vibration the first thing I do is swap on a different set of wheels. Feathered tires once cost me a wheel bearing replacement and axle replacement when I was younger and dumber and didn't know to eliminate ALL of the easy possibilities first.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Only on acceleration sounds like an axle issue and the snow tires are making it more pronouned. Put your other tires back on and see if it still there.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 18 2006
    Hanover, NH
    can you elaborate more on axle issues? its only around 55-65mph - at 75-80+ the problem goes away
    i have a bad tranny mount getting fixed so could that be it
    Mar 21 2006
    Lakeland, FL.
    Try the other tires first.
    I'm back bitches!
    Dec 18 2006
    Hanover, NH
    Will do - going to swap mount first
