Results 1 to 3 of 3
Thread: CEL help
    Veteran Member Three Rings Jdubya's Avatar
    Apr 05 2006
    05 S4
    Dayton Ohio
    CEL help
    CEL came on the other day. Here is the codes:
    16543 - Oxygen (Lambda) Sensor B2 S2: Response too Slow
    P0159 - 004 - No Signal/Communication
    16440 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit: Malfunction / Open Circuit
    P0056 - 004 - No Signal/Communication - MIL ON
    17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
    P1140 - 004 - No Signal/Communication - MIL ON
    Anyone know which rear O2 this is? I'm assuming there are two, one after each cat.
    FI DP | FI CB | JHM IM | JHM TUNE | JHM N20 | SB STAGE III/LWFW | PORSCHE BBK | BBS CH | KONI/H&R
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: CEL help
    well you have 4 O2 sensors... one before each cat on each downpipe and one after the 2nd set of cats on each downpipe.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: CEL help
    Quote Originally Posted by ginkof View Post
    Bank 2, so drivers side. Buy a universal BOSCH 4-wire/heated from a google search... save you LOTs of money.. got mine for 40 bucks shipped..
    only thing is, it wont plug in.. you'll have to cut the wires and join.. not a big deal.
    Also there are 4.. but B2= bank 2 and S2= probably sensor 2.. so yes its the one you can see underneath the car after the cat.
