Results 1 to 4 of 4
    Established Member Two Rings mhorsfield89's Avatar
    Dec 02 2008
    Durham, NC
    04 s4 not starting? fuel pump relay?
    i have a 2004 audi s4. recently it sometimes doesnt not start, it cranks but it doesnt get enough fuel to the engine and either starts and dies or doesnt start. i took it to a local dealership who diagnosed a bad fuel pump. i replaced the fuel pump and still it doesnt start. i connected the old pump to the battery and it works so i dont think that was the actual problem. i have identified that the fuel pump works but there is no fuel or not enough fuel getting to the engine. i believe the fuel pump relay might be the problem. but i cannot locate the relay. can someone help me diagnose this problem or at least locate the fuel pump relay? thanks
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Re: 04 s4 not starting? fuel pump relay?
    Quote Originally Posted by mhorsfield89 View Post
    Or fuel filter.. sorry lost my Bentley.
    Senior Member Two Rings 1.9TDI's Avatar
    Mar 03 2008
    Nogaro Blue B6 S4 6MT, Quartz Grey B7 A4 Quattro
    Orlando, FL
    definitly check your fuel filter, according to the tech at audi, the fuel filter in our cars house the fuel pressure regulater as well, if something goes bad in the filter, it can cause low fuel pressure.
    Good luck
    Senior Member Three Rings dr.evil's Avatar
    Nov 27 2005
    Sparks, NV
    I would defiantly change the fuel filter. Get it from your dealer as there are a few kinds. They can take your vin and get the right one for your car. Pretty simple to replace, see this walkthrough (its for an A4 but was still applies).
    http://www.audizine.com/forum/showthread.php?t=209938
    Just push the clips IN on the line connectors and they pop off. Have fun
    2014 SQ5 Prestige - Glacier White
    1970 Mustang BOSS 529
