Results 1 to 11 of 11
Thread: Cracked Oil Pan
    Nov 09 2008
    Pittsburgh
    Cracked Oil Pan
    Happy Holidays to me :( why not change the oil and oil cooler gasket since its half-decent out, everything went cool. Go to tighten up the drain plug like I've done 100x and get a small hairline crack no bigger than your tumb nail I would say. I just dont want to half ass it with JB weld so I guess Im giong to try to change it myself this weekend. I found a used one for cheap (Is a used Pan Ok ?? ) and having the gasket overnight to me. Now I need your guys advice,tips..info. What the best way to go about replacing the oil pan btw its AEB. Is their away around dropping the subframe or can I lower it to get to the bolts ? While the pan is off, should I look out for anything...I plan to clean the oil pickup screen.
    Thanks in advance
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: Cracked Oil Pan
    Quote Originally Posted by msbc88 View Post
    Thanks in advance
    I don't see anything wrong with a second hand one. Just check it and make sure it hasn't got any clearly visible damage. Might be a good idea to clean it up first so you'd be able to see any cracks similar to what yours has now.
    Dec 25 2008
    home
    Re: Cracked Oil Pan
    hi, my dad and I are trying to fix my sisters car, 2001 A4. I noticed that the subframe gets in the way of accesing some bolts in the rear of the oil pan, how hard is it to drop the subframe, will the engine drop as well can car will stand on its front tires?
    I am assuming the best thing would be to stand the front of the car on jackstands, take the front wheels off, disconect the front sway bar, then the lower control arms and just take it from there correct?
    Jan 19 2008
    Re: Cracked Oil Pan
    Quote Originally Posted by Profoxcg View Post
    You can do it without lowering the subframe, you just have to raise the engine enough. Completely loosen the side engine mounts. Then, loosen the transmission mounts but don't remove the nuts or bolts for these mounts. That gave me enough room to get the oil pan out with a little twisting and turning of it.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: Cracked Oil Pan
    just did this on the lift today. took a bit less than hour and half.
    what i did(the jist anyways):
    marked the subframe
    unbolted all trans/motor mounts from the bottom
    unbolted the snub bracket(this is on a B6, not sure if you are able to do that with the AEB.
    supported the motor
    unbolted the subrame and lowered
    replaced pan
    repeated steps backwards
    it's really not bad to drop the subframe. it usually bolts back up into the same place where it was. but that's what the marks are for.
    and the book recomends silicone gasket. not a rubber one
    good luck
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Dec 25 2008
    home
    Re: Cracked Oil Pan
    one of the bolts that hold the pan (the one inside the trasmission case) was stipped... I was thinking of drilling it out, any other suggestions?
    in case you are wondering how it got stripped? well - my dad didnt know the flywheel needed to be rotated to expose the bolt...
    Sep 17 2006
    SLC, UT
    Re: Cracked Oil Pan
    yeah, that's why i love my LWFW. doesn't need to be rotated.
    but yeah, drill it out. then once you get the pan off you can go from there in repairing the threads
    Current:
    Previous:
    Dec 25 2008
    home
    Re: Cracked Oil Pan
    ill keep you guys posted. in the future I want to get myself an audi, I currently have a 2008 civic Si which i love working on, previous car was an evo IX, also relatively easy to take apart, but im just scared of audi's based on this A4 (sister's)
    Dec 25 2008
    home
    Re: Cracked Oil Pan
    okay, got the bolt out, the pan is loose, now what? I lossened the motor mount bolts and transmision, I jacked the trans mission up but i cant get the pan out.. it appears that its hitting the subframe.
    Sep 17 2006
    SLC, UT
    Re: Cracked Oil Pan
    you just loosened the motor/trans mounts? i completely unbolted the mounts(from the bottom only) and jacked the motor up quite a bit. also dropped the subframe as it's just a few bolts. if you can't get it out with the subframe dropped, then i would consider that as a solution
    Current:
    Previous:
    Dec 25 2008
    home
    Re: Cracked Oil Pan
    I need DIY for dropping the subframe, we manged to take the front bumper out and it was mission, we endup breaking the levers along the front, that attach the bumper to the crash beam, because i have idea how to get them out. also the "sprinklers" that spray water into the hearlights broke... the helms manual i have is horrible.. I need help.
