Results 1 to 22 of 22
    Bklyn
    Left front blinker, not blinking!
    I pulled the old bulb out and one of the contacts had a bit of charring on it as well as the contact inside the socket. I replaced the bulb and still no luck. Should I buy a new socket? As a driving light it works but the blinking function now never works. Help!
    There wasn't much in past threads that I could find
    Veteran Member Three Rings tubbs_4mo's Avatar
    Apr 05 2008
    2005 Audi A4
    Dallas/Lubbock, TX
    Re: Left front blinker, not blinking!
    I am having the same problem. I've searched as well, but only found one other thread with this issue, and there were not any helpful comments. So I'd also really appreciate if someone could lend some insight.
    Bklyn
    have you tried replacing the socket. I might try it tomorrow or Monday if the dealer is open.
    Does your indicator blink fast on one side and normal on the other? That's what I have going on. I just read on VWvortex that it's indicative of something after the relay and that the relay is fine. I'm really suspecting the socket now.
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Try using a dab of solder on the charred portion.
    It just needs to make contact and complete the circuit.
    GL
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Two words.
    Blinker fluid.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I just had this problem when I swapped headlights about a week ago.
    Pull out the socket (not the bulb but the whole socket) and rotate it 180(degrees) and re-insert it.....
    -Sami-
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by Tgr_Clw View Post
    Two words.
    Blinker fluid.
    x2
    http://kalecoauto.com/index.php?main...&products_id=6
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Bklyn
    ummm...that whole blinker fluid nonsense is what killed a similar thread on here. I'll just wait for real suggestions
    Bklyn
    Thanks absolute, I'll give it a shot in the morning.
    Oct 27 2008
    Studio City, California
    when i did the joey mod to my headlights.. after i put it all back together and intsalled my blinkers, they wont blink when i have my headlights on it just throws a code but then my headlights are off or when i am locking the car they blink any ideas?
    Bklyn
    threadjack much?
    the two guys on here that have the same problem didn't mod their headlights. I think your problem is prolly different.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by MurderedA4*20 View Post
    That exactly what happened to me....just do what I advised above, and I guarentee you that it will be fixed
    -Sami-
    Oct 27 2008
    thank you soo much^^^ if i keep my car ima do it right away.. :) and Cyclo i needed help to buddy you got ur answers dont cry.. sorry dint mean to threadjack..
    May 24 2007
    Southern California
    I'd much rather have you do a slight thread jack, instead of making a whole other thread. It really wasn't much of a thread jack. A thread jack would be along the lines of my turbo is making a weird noise...
    thanks. :) merry christmas!
    Kyle
    2.0L Revo GTRS Eliminator
    Bklyn
    No prob murder...
    It's frustrating for guys like me and the other dude to research this same issue with our cars and see how virtually all the threads die because of guys fooling around and/or threadjacking. I found like 7-10 threads over 3 pages that all died with no good answer.
    I am glad however that you found an answer
    I'll try reversing the socket...i'll report back later today
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Try to clean the contacts with the same stuff you would use on battery terminals. water and arm & hammer and a cuetip or maybe some rubbing alcahol. Or you can try a new Relay for the blinkers, it might be stuck in the off position.
    Bklyn
    It worked! I'm not sure if I ended up rotating it 180 degrees or 360 but it worked. Thanks man!
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by cyclo View Post
    Well if you rotated it 360 than you would be back at sqaure one! So yes, you must have rotated it 180.
    Feel free to rep me up,
    -Sami-
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    My turbo is making a weird noise...any suggestions?
    Bklyn
    I know, right!! I turned it what I thought was 180 and it didn't fit...so I kept turning until it did. While I had the headlight pulled out (but still attached) and the turn lamp in it's socket I figured I'd try it to see if worked...sho 'nuf. I was extreeeemely happy!!
    Rep coming.
    400hp,
    don't know what to tell ya...do what I did! Turn that bad boy 180 degrees, curse mother nature for letting the sun go down while you're working on your car and answer stupid questions from your neighbors. Worked for me!
    Oct 27 2008
    when i did it nothing happened
    Veteran Member Three Rings audimymind's Avatar
    Nov 26 2007
    Mililani, Hawaii
    Quote Originally Posted by 400HPA4 View Post
    rotate it 180 degrees
