Results 1 to 9 of 9
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    removing Front seats
    Well i got S4 seats for x-mas..i got the two bolts off in the front but now im kinda confused...how does the rear come out?..is there a write up some where with pictures...im a picture kinda guy..also when i go to put the S4 seats back in should i connect the power and heat first or after the seats are in
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Established Member Two Rings The Russian's Avatar
    Dec 01 2008
    Boulder, CO
    Re: removing Front seats
    when i did mine there were bolts on each of the rails, loosen them a little bit, and then you can just slide the seat (with the bracket assembly) back until it comes off the rails and then you might need to undo an electrical clip for the seat belt detector or something.
    2001 A4 4.2L v8 quattro 5spd: 4.2L V8 swap | Tein SS Coilovers | Straight Piped side exhaust | StopTech Brakes | Custom aluminum radiator | Full Cage | much more...
    1983 Porsche 944: Daily Driver
    2001 Ducati 748: geared down | dry clutch | Termignoni
    Carbon Exhaust
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    There are covers behind the front seats that sit on the ends of the rails. Take those off and you can push the seat all the way back so it comes out of the rails.
    Aug 04 2007
    Cranston, RI/MA
    DOH broke my socket..now i gotta wait till tomarrow when i can get a new one..thanks for the help guys...its 17mm right this thing is from like the 40's and i just played the matching game
    ~Bo
    01 2.8- project
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Damn, wish i got some s4 seats for xmas =[
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jul 01 2008
    Minnesota
    What do you do about the seat airbags??
    Aug 04 2007
    Cranston, RI/MA
    The air bags shouldn't go off. The airbags have a safing sensor which has to be activated and another sensor which has to be activated as well..is it the crash sensor?..regardless they both have to be activated by deceleration rates and then the airbags deploy..and the S4 seats have airbags in them
    ~Bo
    01 2.8- project
    Jul 01 2008
    Minnesota
    Yeah i meant the compatability between the two, are they the same airbags/do they have the same amount of resistance so the computer wont put out a resistance too high/too low code?
    Aug 04 2007
    Cranston, RI/MA
    never thought about that when i get the seats in ill let you know
    ~Bo
    01 2.8- project
