Results 1 to 7 of 7
Thread: mbc?
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    mbc?
    will i see any gains from a MBC on a bone stock car? i hear it does nothing for our cars.
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    Re: mbc?
    If you get chipped it might be a good idea. but its not nessasary. if you dont have it already just dont buy it. But if you already have one then go for it... it wont hurt.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: mbc?
    You will only be able to bump up the boost a few psi so you wont see all that much of a gain. If you try adding too much boost the ecu will start doing things to decrease the power. You might also find that the MBC makes the power feel on/off.
    Dec 05 2007
    Re: mbc?
    You have an 01, so you can do the diode mod to the MAP sensor, add an MBC, and hit ~17psi peak safetly. Use the search function to find out how to do it. The MBC will cost the most (assuming that you don't cheap out. Suggested ones are the TurboX bleed/ball type valve). The diode costs maybe $1 and you will need to know how to use a solder iron.
    Jul 07 2004
    socal
    Re: mbc?
    #1 way to blow up an engine if the MBC fails. Chip the car and run 21psi with the overboost safety still in place.
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Re: mbc?
    I used it when I was stock my N75 went bad so I left it plugged in electrically and bumped the boost to about 12psi at 1 bar is when you hit the fuel cut. I am DBC so I dont know how it would work for you since you are DBW.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Apr 22 2007
    Riverbank, Ca
    Re: mbc?
    I hate MBC's...
    EBC for the win.
