Results 1 to 12 of 12
    Apr 22 2007
    Riverbank, Ca
    I think my MAF went out...
    So all of a sudden part throttle acceleration suddenly became a big issue. It felt like it hit a brick wall trying to accelerate normally if I hit any boost at all. So After a quick check of connections everything seemed to work fine, full throttle showed that I was getting boost but it didnt run quite right. I unplugged the MAF and bam, I got my part throttle back.
    So I decided I would try and clean it, and my dad told me to clean it off with a q tip. After light pressure on the side of the sensor, the sensor piece bent, and when I went to bend it back it broke off. It appears to me that this was the issue, it was just about to break off...
    Does this sound like the right diagnosis to you guys? (I know I have to buy a MAF sensor... but could it be anything else?)
    APR stage 3 with every supporting mod.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: I think my MAF went out...
    Sounds about right. I mean, why would it be back to normal once you disconnected it? I think its safe to say that it is the MAF sensor. Next time i'd just clean the sensor with the spray.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    or run your car maf-less :]
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    It wont run mafless lol, its me5
    Nov 02 2008
    Boulder & Seattle
    Haha I meant get a maf-less setup LOL
    1989 Nissan 300ZX
    Lemons Race Car
    2000 Audi A4 1.8T
    The New Track Build
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    yeah, it still won't.. cant do that until your a 2001.
    Oct 27 2007
    In the lab
    Unless you go standalone like me
    Apr 22 2007
    Riverbank, Ca
    Quote Originally Posted by biketsai View Post
    Ya, well thats what I was going to do... but my dad (mechanic of 10 years) said to swab it with a q tip...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You never want to touch the sensor, either use a spray or put the solution/sensor into a bag and let it soak. It is a sensor not your ear.
    Apr 22 2007
    Riverbank, Ca
    Well, good to know next time.
    Is it really THAT delicate? I mean the adjacent piece was not nearly as fragile..
    Jul 07 2004
    socal
    Quote Originally Posted by andyrew View Post
    Well the sensor part is, it was only meant to take pressure on the front side and if you push it from the side there really isn't any support. Plus you dont want to touch it because you might just end up leaving something on the surface which will just make it worse.
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    ya its sounds like you went into limp mode. They sell MAF cleaner spray. i herd that it works wonders. i would try to clean it before you buy a new one it cant hurt.
