Originally Posted by
GTIBONO
anyone think the apr software will work with the awe fuel pump?
There should be no problems using our Fuel Pump Upgrade with your preferred software. Our pump can easily supply pressure up to the 130bar limiting valve found on the OE rail, so there should be no issues with use of software that works in that range.
juggernaut201
the fuel pump software will put a beating on it i dont think itll hold personally ...
May I ask why you think this? I can understand being critical of a product thats been newly released, but what makes you believe our pump will not hold up? We've put literally tens of thousands of test miles on our pump and have taken many measures to ensure its reliable operation.
