Results 1 to 9 of 9
Thread: Ebay Vag Com
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Ebay Vag Com
    I recently bought a Vag Com on Ebay. I ran an auto scan and came up with no fault codes. Durning the scan there was no control info on the Open Controller screen....am i doing this right? Am i able to run the auto scan correctly since i bought this off ebay?
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Re: Ebay Vag Com
    Quote Originally Posted by bmags88 View Post
    Hmmm... are u sure this is a genuine VAG-COM Ross tech cable. I bought em all: EBay, ECS, and finally the "original" multi-hundred $$$ unit from the mothership truely gives me the full functionality. There is a key that unlocks all of the software features in the VAG-COM cable.
    I think u can scan with a regular cable though. That is not even certain though as they're constantly releasing new software versions.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    Re: Ebay Vag Com
    how about a screenshot
    2010 A4 Avant
    Mar 27 2005
    The Cold North
    Re: Ebay Vag Com
    Quote Originally Posted by A4SoftWalker View Post
    You are correct. the only way to get full functionality of the vagcom software is with a real vagcom cable (dongle). The generic ones online allow for data logging, some changes and clearing of codes, but not full access. Also like you mentioned there is NO software support/upgrades for the generic cables. Plus the older key codes could only be registered to 1 computer. the new hexcom is a different story.
    I bought one of the ECS generic cables as a cheap replacement for my real cable when the puppy chewed on the real cable. And well the generic cable works like crap.
    I will end up using my VAD going forward since it does everything my vagcom does and it is more convient.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Re: Ebay Vag Com
    I have a ebay vag com from alpha bid and a bootleg download version of vag com and it does everything lol
    barrett
    2019 SQ5 Prestige
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Ebay Vag Com
    Quote Originally Posted by texasboy21 View Post
    barrett
    How did u get it to do everything
    May 13 2008
    NoCal - EBay
    Re: Ebay Vag Com
    Quote Originally Posted by EBG 18T View Post
    What is VAD EBG 18T or anyone is it like VAG-COM???
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Mar 27 2005
    The Cold North
    Re: Ebay Vag Com
    VAD
    2020 Chevy AEV ZR2
    Established Member Two Rings andrewbb89's Avatar
    Aug 21 2008
    Re: Ebay Vag Com
    i have the ebay cable and i have found you cant do a entire scan of the car. you have to pick each module and scan it. its perfect for when say the airbag light is on, just scan the airbag module. once i get a little more into tweaking my car, i think illl spring for the real thing.
