Results 1 to 27 of 27
    Registered Member Two Rings
    Dec 19 2008
    maryland
    Thinking of buying this B5...
    well what do all you guys think and what service whould be needed soon?
    http://www.autoshowcasecars.com/deta...o-3560826.html
    Thanks
    Zach
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Thinking of buying this B5...
    condition looks good, I was confused for a min b/c it's a '99.5 though. It has all the goodies of the "Facelift" cars, but has the single-DIN audio.
    $7900 seems a bit high though. I don't care about the mileage, that's ~$1K too high for a car lot.
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Timing belt for sure. Ask if it was replaced already.
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Dec 19 2008
    maryland
    so like 7 for a car like that or more towards 6500?
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    if i were you i would try and find one with sport suspension. body roll on that is going to suck trust me i have non sport suspension it sits higher than my parents minivan. i paid 4500 for my 98.5 i think for 7500 you could get a nice 01 with the ko3s and you can get a hammer file for that
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    Dec 19 2008
    maryland
    ko3s?
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by gooddriver? View Post
    ko3s?
    The type of turbo. What's up with the missing shifter knob as well.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Wow, that interior is mint.
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    K03 is the stock turbo on the A4. An upgrade is a K04 turbo (more power) and another upgrade is the GT28R turbo. There is also BT setups (big turbo) which are GT30, GT32, GT35.
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    ko3s = k03 with different compressor wheel for higher output. available stock on 01 and up. the advantage of the 99.5 car is that it is aeb engine which is has the large port head and stronger internals, while still having the facelift body. read the faq. id post a link but im lazy so....
    anyway the year is right, it just sucks that its not sport susp. that can be fixed but you gotta buy aftermarket suspension. definetly check to see if the timing belt and water pump have been done. also inspect the brakes and upper control arms, as well as cv boots and any fluid leaks. if timing belt has not been done, i would at the very least ask them to take off that price (the cost for you to have the belt replaced at a audi dealer ~800-1200 USD) before you consider purchasing it.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    price is a bit high but at least it's a 99.5...I'm so happy I got the facelift version
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    it doesnt have a different compressor wheel.. the shaft is 1mm thicker so the factory upped the boost from 7 to 10 stock. you can take a pre 01.5 car, turn the boost to 10 psi and be just as quick as the 01.5.. the cars make no more power when chipped then the other. some tuners do add more boost to the 01.5 but they make the same power at the same psi and tune.
    now, i'd personally NOT get that car.. no bose! creame interior sucks! that car is worth ~5000 tops if you know what you are looking for.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Get a b6
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Jul 01 2008
    Minnesota
    Wow thats a pretty unique car isnt it... Its a 99.5 with a single-din radio like said above, it also doesnt have the instrument cluster screen and it has a 4-spoke steering wheel.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Or it could be a 99 with facelift headlights....
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Jun 26 2008
    00' Noggy Stg2
    Quote Originally Posted by Dallas09 View Post
    thats not unique, 99.5 had single dins and the lcd is only an option, was from 97. even 00-01 cars can have the plain cluster. also 4 spoke wheel is because it isnt a sport model
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Quote Originally Posted by Rhinop21 View Post
    no it couldnt, it could be a '99 with facelife headlights, tail lights, and interior....but lets be serious
    Quote Originally Posted by djwimbo View Post
    he does live in maryland...shit is EXPENSIVE there compared to michigan...but it still may be a little high
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Senior Member Three Rings a4mafia's Avatar
    Aug 22 2008
    B5 A4 Avant. Ford F250 PSD. Mazda3. Raptor 700r.
    Cincinnati
    tad too high on the price. looks clean though
    Apr 06 2008
    Brandon, FL
    Quote Originally Posted by black99.5a4 View Post
    hmm... i thought that the fin design on the compressor side was slightly different. i may be wrong though.
    Current whip:
    RIP:
    Senior Member Two Rings BLK_A4's Avatar
    Dec 22 2008
    Fox River Grove, IL
    Its very clean!! but from what i could tell it looks like the odometer screen is pixalating but i might be wrong. But ya that is a little high you could probobly get it down tho.
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Or it could be a 99 with facelift Headlights, Grille, Fogs, Tails, Exterior door handles, Exterior Trim, Fenders, Air Vents, Climate Control, Shifter Surround, E-brake handle, And center console buttons.
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    its the same car as mine when I got it stock. That is a bit steep with the mileage. got mine with 50k miles 3 years go for 10k...with sport package. Try and find one with the 3 spoke steering wheel and stuff.
    Is it just me or do b5's look way better in pictures than in person? lol.
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Seems quite a clean car.
    Definitely not a pre-'99.5 with facelift bits added on.
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Quote Originally Posted by Charlescrs6 View Post
    its because while people walk around the lot looking at cars, some people pocket shift knobs. I work at a dealership and we take the shift knob of some cars that we get in, as some cost $100+ OEM.
    Hell i wouldnt mind having another B5 Shift Knob to re-upholster with something else.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Dec 19 2008
    maryland
    Ok so basically keep looking or get the price down.
    Also I do want a B6 but to much money.
    But you said if it has a 3 spoke wheel then its got the sport suspension right.
    And Merry Chirstmas to those who celibrate it
    Thanks
    Zach
    Apr 06 2008
    Brandon, FL
    you could also get a s4 or a 2.7t manual a6 (sleeper status ftw). look for one being sold cheap because of blow'd up turbos and upgrade.
    Current whip:
    RIP:
    Dec 19 2008
    maryland
    can't get a S4 I'm 16 and this will be my first car talk about insurance lol
