Results 1 to 34 of 34
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Kitty or no kitty
    Finishing up my Stage 3 here soon and next comes the exhaust. Would i get any butt dyno from romoving the cats or hardly any? I'm debating if i should go catless or just stick with them.
    If i'm looking at only 2hp gain than i should probably keep them because it will be somewhat more quiet. How loud really is the exhaustwithout them ? Can you chat it the car while driving? Last question, do i need to get o2 cell eliminators or just drill a hole in the pipe and put them there?
    Aug 29 2008
    01 s4 stage 2+
    nowhere
    Re: Kitty or no kitty
    what kind of exhaust do you have?? it depends on what you have i have the ssac with cats removed and its fine in the car you can chat all you want...it gets loud when you step on the throttle tho..
    good bye s4 hello kenne bell cobra
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    I think its a substantial gain but no idea what, you could also get hi flow cats. thats what I have, but I dont have any numbers to back it up yet.
    you can scrap the secondary o2's if your going to get it tuned, they can just shut the code off so it wont throw the CEL, but if your not tuning it then you need them.
    as for the sensor itself I dont think you could go wrong by placing them in a similar way as it would sit in the stock ones.
    '00 Nogaro Blue S4
    Aug 06 2008
    Canadia
    pre cats generally rob the most power.
    I personally hate the smell of hydrocarbons, so i would leave cats in place.
    the B5 S4 is like the mafia... there is only one way out!
    Jan 03 2008
    Iowa
    If there is no gains or no serious restrictions with cats in place than i would leave them on. I plan on Tracking my car and doing some highway pulls here and then so i dont want anything effecting my motor like not enough exhaust flow ect.
    As far as the rest of the muffler it's going to be custom dual pipes no resonators or mufflers, straight pipes all the way back and than dual tips to finish it off.
    Oct 29 2005
    10speed
    San Francisco, CA
    HUGE gains when taking out the cats... with turbos, the name of the game is flow... you need the whole system to breathe easy
    - Clint
    Jun 14 2007
    2000 S4
    Connecticut
    ^^ Agreed, I have piggies, test pipes and my Twin one... All that's in my exhaust is a muffler. It's really not THAT bad, the cabins of the audis are great they keep a lot of the noise out. And only once in a while you'll smell the lovely smell of fuel, but only with the right winds :).
    Aug 06 2008
    Canadia
    ASP says they rock cats on their website, look up the B5 S4 3" DP's.
    Jan 03 2008
    Iowa
    Anyone have any logs or possibly dyno numbers with or without cats? If go without cats than i should look into some kind of a muffler at least.
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    Removing my cats was one of my favorite $ for $ mods... Get rid of em!
    Cats are for Pussies
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    The under car cats are fine and you should leave them in. It's the cats in the downpipes that kill performance.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Jan 03 2008
    Iowa
    Eyes on me bitch can you hear me rolling through the hood loud as fuck lol Another thing is i dont want to atract cops with my loud muffler scaring babies.
    I will leave the cats on and see if it's hurting my preformance. I should have my muffler shop make me a quick disconect right before the cats so when i go to the track i can take them off. Orrr.... Maybe i need to invest in a cut off muffler :)
    May 04 2007
    LI,NY
    Main cats DO hurt performance big time, but removing them does not automatically mean you will be loud. My car is VERY quiet, and I have no cats at all. Its the rest of the exhaust that matters most. My car is almost silent when cruising, nice tuned sound when you get on it. No cats and all mufflers are straight thru... Size of them is key..
    Jan 03 2008
    Iowa
    Quote Originally Posted by ENDEE666 View Post
    No cats and 2 1/4" all the way back does that sound loud Take in note that this is dual 2 1/4" all the way back.
    What did you do with your rear o2 sensors? Tuned the engine light out or??
    Aug 06 2008
    Canadia
    dual means two, duel means a match between two rivals.
    Jan 03 2008
    Iowa
    Quote Originally Posted by MacDaddy View Post
    hahaha thanks man i kinda knew i was spelling it wrong i was just lazy to look it up.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by GetAwayFromMe View Post
    The CEL can be coded out from a custom tuner, he uses SSP so yeah, it's coded out .
    Jan 03 2008
    Iowa
    If were to leave the cats i would be loosing what? 10hp? If so i dont think 10hp is worth the fine i would get if i get pulled over.
    Jun 01 2008
    Apopka, FL
    less than that.. probaly more like 7-8HP @ 400AWHP, and about half that with a high-flow performance cat.
    Virginia has CAT checks every year for their inspection, so I'm getting primary cats in my DP's from JHM. Plus, I got tired of the smell of hydrocarbons as well, it's fun the first time but is pretty lame when you're sitting in traffic and all you can smell is fuel. Dirties up the rear of the car too.. and that's lame as well.
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    if you are running high boost on ko4s you will see alot of gains from cat-deletes. the turbos won't run outta breath so quickly. so in other words if your going to run 19+psi (est.) you will see pretty big gains on your topend. but if not you will still see some gains but not as noticable. plus the smell isn't so bad, you only smell it when you go in reverse, and briefly when you come to a stop with the windows down.
    Jan 03 2008
    Iowa
    -If it's only that much than who cares i'll leave them bitches on. We dont have inspections here in Iowa but no cats is ilegal and i think the fine is near $200 while fine for loud muffler is only $50.
    I just dont want to run into any problems with my turbos because my exhaust didnt have enough flow and stock piping is alos kinda small.
    Jan 03 2008
    Iowa
    I will be running 19+ PSI I should look into hi flow cats that would help instead of deleeting them. This is driving me nuts. I will be putting my motor back in i a week or so and i still cant decide
    Feb 07 2007
    Dover, DE
    -I just dont want to run into any problems with my turbos because my exhaust didnt have enough flow and stock piping is alos kinda small.
    as long as your pre-cats are taken out, and you don't run really high boost you will be fine. but if your want to run 22+psi atleast get some cutouts. otherwise you may put too much strain on a already sensative turbo.
    Feb 07 2007
    Dover, DE
    if i could do it over again. i would go 3" dp with high flow cats and electric cutouts
    Feb 07 2007
    Dover, DE
    i would do high flows at the very least then. you should be fine unless you go real high. you would see good gains if you deleted them though. it really isn't as bad as other cars ive owned with deleted cats.
    i vote highflow or delete, definatly
    Jan 03 2008
    Iowa
    Since you have Marcs tune what is his boost set at? I got his fueling kit but my motor is out so i didn't have a chance to run it yet.
    What about stock piping? 2.25" is kinda small right?
    Feb 07 2007
    Dover, DE
    i run a daily 22psi. but i run 24psi on "weekends". and all this is on his ots fueling, i haven't changed a thing on his tune yet. i would talk to marc about the dp's size though. i would think piggies would be fine but i have custom 2.5" piggies since ive been stg3. so i don't know if 2.25 is good enough or not.
    Feb 07 2007
    Dover, DE
    you run a mbc with marcs tune. so the boost is set to whatever you'd like
    Jun 01 2008
    Apopka, FL
    2.25" is just fine for 250horse.. but for anything more than that you'll see gains with bigger piping, it's usualy about 5-10horse on k04's.. which is why people do piggies, because at $875 that's $87.5/hp at the max. Not very cost effective.
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Does anyone have any before and after dynos of cats and then without cats?
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Jan 03 2008
    Iowa
    Quote Originally Posted by o3spec View Post
    hmm.... I dont rememember him telling me that i need to a MBC so i will have to ask him about that.
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    I have the FI Wide Mouth DP's with straight pipes and I also got a set of their 100 cell high flow cats and their is no noticeable difference except sound. I can tell a slight difference on the top end, but that's it.
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    I just deleted the cats and resonator on my noggy (stock exhaust) this weekend. All that is left is the stock s4 muffler. It's not much louder than with the resonator and cat setup, at idle and cruising speed. Two 2 1/4" downpipe test pipes to 3" straight to the stock muffler.
    Although for the most part, even [I]during[I] full throttle it's not as loud as something you may hear from an idling EBAY rice muffler (lol), but it doesn't need to be in order to feel and sound great. To me it's still quiet enough to have civil conversations in the car, although as you go deeper into the throttle and begin to build boost, you'll notice that there is just a little more kick to it and all of the sudden the car just becomes to coming alive. You'll notice the throttle response gets much crisper and there is just a little more *umf* to it. To me this "stealth" exhaust is perfect for someone who appreciates the the natural tone of this car's exhaust, although doesn't want it bleeding through their ears!
    Innovate.
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Well you can run it in parallel with the N75. So you have the called 22 psi or under. N75 will only allow what the tune is good for. If you run it in stand alone then you can.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
