Results 1 to 14 of 14
    Established Member Two Rings nycats4's Avatar
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    aftermarket navigation install ???
    wazz up guys and merry x-mas.
    I got some money to spend on the audio system and was wondering what you think about my proposed setup. pioneer avic f900bt, infinity component speakers. I already have a 10" sub with enclosure along with 2 pioneer amps sitting in my garage from my previous car I sold. Also have a question...since the car has 10 speakers will the headunit control all the speakers individually providing I get the appropiate harness from somewhere? I searched crutchfield and they don't carry a harness for the 04 s4. I would like to get more bass out of it so I'm installing the sub and amp directly from headunit. anything I left out? thanks
    Feb 26 2006
    Re: aftermarket navigation install ???
    May want to try using the harness below with the stock speakers first to see if you like the sound. I did that with an Avic Z2 and it sounded much better. I also added a sub with a small amp in the cubby hole in the passenger rear for additional bass.
    - Metra 99-9102 dash kit
    - Metra 70-1787 wire harness
    - Scosche VWA-4B or equivalent antenna adapter
    Senior Member Two Rings gaogi's Avatar
    May 08 2005
    2008 S4 Avant 6MT
    Irvine, CA
    10 speakers, LOL. Audi counts the tweeters as a speaker, so between the front and the rear, you have 8 "speakers". Add the center and subwoofer, and you have 10. With the Pioneer unit, the only speaker you'll lose is the center speaker, otherwise, the aftermarket unit can control a 9 "speaker" system no problem.
    The Metra 70-1787 is needed if you want to use the stock amp to drive your speakers. If you're going to drive the speakers with your own amp, then you need to get the Metra 70-1784.
    2024 Glacier White RS3
    B6 ('02) -> C6 ('06) -> B7 ('08) -> MK6 ('11) -> 8V ('15) -> 8Y ('24)
    Registered Member Three Rings yakendo's Avatar
    Dec 11 2007
    2005 S4 Tiptronic
    San Francisco
    Tweeters are very important speakers in any set-up.
    The wire harness & install kit is spot on.
    IMHO: speaker choice is entirely subjective-if you like their sound quality that all that maters.
    What many people do is just install aftermarket component expecting intrinsic perfection-they are dreaming.
    If you do proper upgrade with adequate sound deadening material, proper enclosure specs & mount all door speakers to MDF it will be sick!
    If not, buy the head unit that best meets your needs + proper adapter and you will be verry happy; & richer, too.
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    thank you for the info, i'm going to order the headunit and harnesses. after the install if i want a little more bass i'll install the sub with the amp in the trunk.
    again thnks
    Dec 11 2007
    2005 S4 Tiptronic
    San Francisco
    Good luck with the project!
    Would you post HU post-install pictures? The Bose set-up is ok for me-but- I don't have Nav.
    So, if I don't trade my S4 for a S5 I will be adding Nav to my S4; soon.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    OP, did you ever purchase/install this?
    I just got F90BT and I need to get a correct harness and dash mounting kit and wondering what you got and how it looks.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Established Member Two Rings rsquattro's Avatar
    Sep 18 2006
    US of A
    I'm also curious, looking into the F900BT. The stock Audi headunit is double-din, correct?
    Nov 27 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Quote Originally Posted by rsquattro View Post
    yep
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    I went to different shops in my area to do the install and all of them wanted close to 400.00 to put the HU in. They also said that I would be losing the use of Audi Telematics function and steering wheel controls. Anyway I made an appointment to a recommended shop (after saving some money) and in 2-3 I will have it installed along with other stuff. I will definately post pics of the results.
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    Well I finally got the pioneer f90bt installed and it works great. I also got 35% tint all around done at the same shop. The only thing i'm waiting to install is the metra bracket aroung the radio and the subwoofer as well as the amp. Like I said before the telematics and the center speaker will not work with this HU. The sound is much better than the audi unit as well as features, including bluetooth which works great. Will post pictures of the finished product tomorrow.
    Jan 13 2009
    Vegas
    Any update of the final?
    Sep 18 2006
    US of A
    Also would like to see the unit bezel installed just so I have an idea of it..
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    The final install was done yesterday and I posted pics under new thread "avic-f90bt finally installed :-) "
