Results 1 to 8 of 8
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    DDM HID kit power question
    Hey guys merry christmas.
    Well I got my DDM 55w kit in the mail today. got the headlights out and hte ballasts out too, but now i'm stumped. how do i connect the power to the new ballasts? There's a connector from the new ballast but it's not like the old ballast where you plug it directly into the ballast. stock headlights other than that. will i have to cut some wires and use some electrical tape to make the power go to the ballasts?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Re: DDM HID kit power question
    You need a 9006 harness plug
    Jul 07 2007
    Tempe, AZ
    would radio shack have that harness plug?
    Jul 07 2007
    Tempe, AZ
    also, just doing a little thinking here.
    how do i get the wires to fit into that harness? saw some pictures of it, doesnt look like you just place a wire into the harness.
    would it be possible to take the connector from the ballast, shave off the top of the connector so the 2 prongs are accessible, and just solder/electrical tape the positive and negative wires to them?
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    Quote Originally Posted by Jung View Post
    I just cut off the stock connector and connected the 9006 harness which can be found at most auto parts stores. Works great
    EPL Stage 3 with a bunch of other crap.
    Jul 07 2007
    Tempe, AZ
    any link to this harness?
    would these work? http://cgi.ebay.com/ebaymotors/Nokya...Q5fAccessories
    Apr 13 2008
    Tennessee
    I used the stock wiring, hooked the power wires to some 16 gauge wire with those sidebyside crimp connectors, then put some female spade terminals on the end of the 15 gauge wire and plugged those onto the power connector for the ballast
    Jul 07 2007
    Tempe, AZ
    Quote Originally Posted by quickaudi View Post
    i ended up at autozone and bought some 9006 connectors. I spliced some wires together with some twisting and mad amounts of electrical tape. they're secure.. I'll put them in tomorrow morning and make sure they work well.
