Results 1 to 26 of 26
    Veteran Member Four Rings Styleprojekt's Avatar
    Nov 17 2006
    Salt Lake City
    Camshaft Position Sensor Help
    Hey guys. Audi diagnosed my check engine light was triggered by a bad Camshaft Position Sensor. I know there are 4 on the 3.0 engines, top-rear on each bank of the engine. There is a Sensor faulty on "Bank 2" of my engine. Now, how can I tell which exact one it is? (also, what side is bank 2?)
    I dont wanna spend $185 for a sensor plus labor there...i got their part number and pulled them up for $30-35 a piece. Anybody gotten one of these and replaced it themselves? Any input to help me out?
    Cheers everyone and Merry Christmas Eve
    Jan 24 2007
    Re: Camshaft Position Sensor Help
    i believe bank 2 is the driver side
    Dec 03 2005
    2 pedals 1FG
    connecticut
    There should only be two camshaft sensors on the 3.0. One for each head. If the 3.0 is similar to the 2.8 then one side is up front and the other is out back. [I know the 2.8 and 2.7 better than I know the 3.0 so I'm just speculating about the 3.0 here.]
    -Doug
    Established Member Two Rings nezach's Avatar
    Nov 03 2007
    02 A4 3.0 Quattro 6spd
    Chicago, IL
    It looks like there are 4 of them.
    16. Valve stem oil seal
    17. Camshaft Position (CMP) sensor
    Cylinder bank 1 (right) Camshaft Position (CMP) Sensor -G40-:
    Cylinder bank 2 (left) Camshaft Position (CMP) Sensor 2 -G163-
    18. 10 Nm
    19. Camshaft Position (CMP) sensor for exhaust camshaft
    Cylinder bank 1 (right) Camshaft Position (CMP) Sensor 3 -G300-
    Cylinder bank 2 (left) Camshaft Position (CMP) Sensor 4 -G301-
    20. O-ring
    21. 10 Nm
    22. Camshaft Position (CMP)sensor housing
    23. Gasket
    Left head is driver side.
    Right head is passenger side
    Nov 17 2006
    Salt Lake City
    Thanks for the replies. I was able to make out from Bentley Manual that there are 4. I just dont know how i can tell which sensor is bad :( i think ill call Audi again on the 26th or whatever and see if i can get the codes they pulled then go from there
    Aug 26 2005
    Yeah, unlike the AMB, with VVT on the intake cam, the 3.0L has variable cam timing on the intake cams and exhaust cams.
    Aug 26 2005
    Quote Originally Posted by Styleprojekt View Post
    Each sensor has it's own DTC number. What is the DTC recorded?
    Oct 29 2005
    10speed
    San Francisco, CA
    damn them! lol
    - Clint
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    yup, get those codes from them. they should also be able to tell you exactly which sensor is bad, and if you have a good service tech. open the hood and have him point it out.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    dam !!
    I just replaced one of my Camshaft position sensor 4 monthes ago at stealership.
    Paid $350 including part and labour.
    Nov 24 2014
    DMV
    Hey guys,
    I'm trying to replace the bank 1 cam shaft position sensor. My car was throwing the p0342 code "bank 1 low input" sporadically for a while but was running fine until this morning. I tried turning the car on, it cranked but wouldn't start. I tried again and it turned on but stalled immediately, giving it gas didn't seem to make a difference. I bought the new sensor and I'm trying to replace it but I can't find where it is. I purchased a bentley manual this morning but it's wont get here for a few days & I don't want to bum rides all weekend.
    The diagram nezach posted helps a little but I still don't know exactly what to move/where that spot is. If I understand correctly the bank 1 sensor is on the passenger side on the rear side of the motor (by the windshield not the radiator) right? I can't actually see where this assembly is when I look at the engine bay. Hope someone can chime in, as always positive input is appreciated!
    p.s. I did remove the plastic audi cover to look. I'm not that much of a noob, haha.
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    front side under the top timing cover(assuiming its sensor 1 bank 1), cover pops right off and two 10mm bolts to take out the sensor. Which sensor does it say? G40, G163, G300, or G301?
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Nov 24 2014
    DMV
    You're probably thinking of the crankshaft position sensors blitz, the camshaft position sensors are located on the back of the engine when you're facing it, closer to the windshield. I got my bentley manual but that diagram above is what I used to find and replace it. I don't know for sure which sensor on bank 1 it is since I only used the OBD scanner at autozone and the car still wont drive well enough for me to get to the dealer/parts store. Also, for future reference bank 1 IS on the passenger side and bank 2 is the driver side when facing the engine. In order to get to the sensors on bank 1, the easiest thing to do is remove the intake tube connected to the airbox and they're both right underneath. It has one screw I removed using an allen tool, you can pull it right off (gently).
    I replaced the sensor but the car still started roughly so I ended up doing a tune up & replaced my plugs/coils and did the valve cover gaskets since oil was leaking into the spark plug holes and onto the engine especially on bank 1. It still started rough so I thought about it and did some more research and I'm going to replace my fuel pump. The car was making a loud humming noise for the past two weeks or so (I figured it was just a fan from using the AC since the weather has gotten warm here in VA). From what I've read that was the sound of the fuel pump failing. Also, the car sputters alot when I start it, and when I give it gas it makes a strange vacuum noise and almost stalls, if the pump has failed that would make sense since gas isn't being delivered to the engine. I should be done with the job this weekend, luckily my buddy is letting my drive his mk3 jetta in the meantime. I'll keep y'all posted, thanks!
    Nov 24 2014
    DMV
    Also, my car is also a 3.0 like the original poster. Didn't mention it but just throwing it out there to clear up any confusion.
    Jul 31 2014
    NH
    Quote Originally Posted by f0reignfeatures View Post
    no i was thinking camshaft but forgot they are all on the back of the 3.0(I've only worked on 2.7t an 1.8t, had a 3.0 long enough to pull the motor and sell for $100 haha) those number i said are still the camshaft sensors though.
    Aug 27 2013
    Philly
    The cam sensors are here on the 3.0. One torx bolt holds them in. Just be careful when removing so you dont snap them as they are fairly fragile. Should take no more than 10 minutes to swap the sensor.
    Remember. When it comes to electronics, only buy genuine Audi parts or you can expect to have problems.
    Mar 02 2015
    miami
    sorry for bumping an old thread, but im having a similar issue. im getting p0366 16750
    which cam sensor is Camshaft Position Sensor (G300) ?
    Nov 24 2014
    DMV
    Sorry to bump an old thread but I just wanted to 2nd that using OEM sensors are the only option when doing this job. I tried Hella sensors and the car would still start roughly as I had described above. I made the mistake of replacing and throwing away the old fuel pump, which was working just fine, because I thought it was the problem (foolish I know). All of the sputtering and vacuum noises were still there after the fuel pump job but went away when I swapped the hella sensors out for new OEM ones.
    Another tip, the little rubber gasket/o-rings on the sensors are kind of thick when they are new making it very difficult to put them into place. The o-rings from my old sensors were still in good shape so I carefully removed and re-used them. Once I did that the sensors went into place with no problems and after a year I have no issues.
    As far as flip's question about which sensor is which, the easiest way to find out is by plugging in to a vag-com, my local VW/Audi guys were able to do this for me for free and tell me exactly which sensors were faulty.
    Senior Member Three Rings diuvic's Avatar
    Feb 15 2012
    Indiana
    Huh, I thought Hella was the OEM Supplier for a lot of sensors on our cars. If anyone has the time, I get this in VCDS:
    17746 - Camshaft Position Sensor (G40)
    P1338 - 001 - Open or Short to Plus - Intermittent - MIL ON
    Where is this one located? Driver side or Passengers side? My car starts right up and doesn't sound rough or anything. Is that weird? Hmm....
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Quote Originally Posted by 8TR View Post
    2001 Audi 2.8 a6 cam sensor replacement: Driver side Is there a trick to removing this? there is a hose that seams to be in the way the clamp holing it on,It is turned so I cant get it on. Any help would be great! Sorry I cant figure out how to start a new Thread
    Wrong section. Try the C5 A6 section of the forums.
    Audi Club Bay Area
    Dec 19 2013
    Quote Originally Posted by SJorge3442 View Post
    Remember. When it comes to electronics, only buy genuine Audi parts or you can expect to have problems.]
    While this is true in a way, you don't have to buy the oem part. You can buy the OEM manufacturer part for much cheaper. Audi doesn't make parts , they have other companies make them and stamp the 4 rings on it. For example our oxygen sensors and cam sensors, MAF and Map sensors are all made by bosch. The oem audi ones even have the bosch logo on them by the 4 rings.
    Shop smart and you'll save a ton of cash on car parts.
    Audi Club Bay Area
    Established Member Two Rings Garf's Avatar
    Aug 23 2016
    Audi A4 B6 3.0 Quattro 6MT
    Toronto, Ontario
    I got a P0025 or 16409 error code.
    I picked a new sensor but the error message logged on my Autel scanner says "B Camshaft Position Timing Over-Retarded Bank 2" I know is it on the driver side, but which one? there is two on the driver side.
    Nov 24 2014
    DMV
    Why not try replacing one with the new sensor and clearing the code? If it comes back switch it, if it doesn't then you're probably good. Bank 2 is easy to get to and it should only take you a few minutes to swap. In my case I had to swap both sensors on Bank 1 (the side closest to the airbox) in order to get the car running properly, so don't be surprised if you need to pick up another. Then again my error code was completely different.
    If you get it all figured out don't forget to post on here for future reference, good luck!
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
    Aug 23 2016
    Toronto, Ontario
    I just replaced the sensor on the driver's side and cleared the code. Drove the car for a while and the engine light never came back on. Fingers crossed it stays that way.
    Before doing the sensor change, several people told me that the driver's side is the easiest to change. Well, I have the say, it is the worst side to change because of numerous wires, tubing and the stupid coolant reserve tank that gets in the way.
    If any further sensors go, the air box side looks a lot more open space to get at.
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Quote Originally Posted by Garf View Post
    Hi i am running in to same problem just can not locate the sensor. Would u able to snap a picture and point it out for me ? I am getting code p034500. Camshaft position sensor circuit bank2. So i am guessing one in the driver side is the bank 2 right ?
    Veteran Member Three Rings Protection's Avatar
    Feb 24 2011
    Alfa Romeo Giulia Quadrifoglio, MK7 Golf R, B5 S4, B6 A4, B7 RS4
    Long Island NY
    The ones for the passenger side (bank 1) are where the connectors plug in at the red arrows. They are located in essentially the same position on Bank 2, just beneath the coolant reservoir
