Results 1 to 6 of 6
    Apr 04 2007
    PHX, AZ
    Coilpack questions
    I am pretty sure that I have one or several coil packs going bad. After my car sits for a period of 8 hrs or more, it will have a rough start then a rough idle, loss of power, and flashing CEL (this usually happens in warmer weather). I will usually slow the car down, shut it off for about 5 minutes and then I will be back to normal with no flashing CEL anymore.
    So how do I determine which coil pack is bad or should I wait until it is completely bad to replace. I am not about to replace all 6 of them. Will a CEL scan tell me which one to replace?
    Thanks for any help and Happy Holidays!
    Paul Cordero
    [email protected]
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Coilpack questions
    Quote Originally Posted by BSIXER View Post
    Usuallly while ure driving the Engine light will flash at u thats wen u kno there def. coil packs
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    i would do it right and just replace all of them , i'm assuming you have a 3.0 (6 coils) i'd also change the plugs
    vag'ing will indicate which cylinder is misfiring , that'll be your culprit.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    Quote Originally Posted by illaudiill View Post
    how about if there's no CEL and when I pull the code from VAG,
    there's a code on cylinder 5 misfire.
    and I just replaced NGK spark plug few monthes ago.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by monkey323i View Post
    Replace it ...Vag it ....if theres no cylinder fire then uve fixed it.....they say if u have at least two going to replace all of them
    http://www.audipartssuperstore.com/c...roducts_id=473
    Jan 24 2007
    if you want to diagnosis the problem. vag it and get the code it should be P0300 & P030*. which ever cylinder that is misfiring from here make sure you clear the fault code. If you want to make sure it's coil simple way to check is removed coil from other cylinder that is not misfiring and install it on cylinder that is misfire. From there vag it to see if the P030* changed to the cylinder that you just swapped it too. If it did it is the coil pack that is bad.
