Results 1 to 4 of 4
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Oily windshield, how to remove.
    I am not sure what the p/o did to the car as far as cleaning. I use a good wash all around, then use invisable glass to clean all my glass and then i apply rain x to the windshield.
    there are spots that when it rains, the wipers go over, but only certain spots leave nasty oily spots that i cant see through. What can i use to get ANYTHING off my windshield so i can have a clean slate again?
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Nov 13 2007
    '07 A3 2.0T
    Tampa, FL
    Re: Oily windshield, how to remove.
    I would try cleaning it with isopropyl alcohol and see how it goes, it will remove wax so it should take off whats on there, if not, you may need to go to something acid based, but that can be dangerous if you aren't careful.
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Make sure you clean the blades as well. They could have picked up some "gunk" and are just redepositing it with every pass.
    Jun 26 2008
    00' Noggy Stg2
    i'm changing the blades today to rain x blades. which is why i wanna get the windshield cleaned off so its not constantly trasnfering shit from 1 surface to the next.
    thanks for the alcohol suggestion
