Results 1 to 27 of 27
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    Question 2.7T swap into the B7???
    Does anyone know if this has been done... let along if it would be possible?
    DUH! an Audi
    los angeles, CA
    Re: 2.7T swap into the B7???
    yes it is possible and has been done 1 time, by who you might ask? ABT, look up their as-4. I was reading about ABT today, so thats how I know, but I believe they used an rs4 engine.
    so, yes it can be done, is it sick? heck ya!!!
    thats why you wear your abt stuff proudly.
    -randy
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    As I recall the 2.7T engine had lots of problems though.... If you're going to spend the money on a swap I would either go BT or step up to the 3.2 and get a SC.
    Or try to fit a V8.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Jan 01 2008
    Long Island NY
    If you are looking to spend big money i would buy an A4 3.2 go to HPA Motorsports and have them try to fit a R32 Twin Turbo Kit to it since the Engine Block is very similar if not the same.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    ^^^That or C2 came out with a turbo kit for the R32 that is pushing really high numbers!! Not sure if it will fit the A4 but i mean like you said same engine.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Dec 11 2007
    San Diego, CA
    My roomate use to have a B5 S4 with K04's and he says that once i get my stage 3 in that it should be faster then his car was. so we will see.....
    FRRG Southern Ring
    Dec 11 2006
    Boston
    Quote Originally Posted by Sal_B7 View Post
    hhhmmm a lighter stage 3 s4 car being slower than an APR stage 3 A4... doubtful. Considering stage 3 s4's run mid to low 11's and a stage 3 a4 runs mid 13's, maybe high 12's.
    Stage 3+ RS6's
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    r32 is not the same engine at a 3.2 a4, lets start there, the "vr" motor was designed for the small space it was given, it is not a true v6- nor a true inline 6, if you look at the coil packs, they are in a staggered offset which looks something like this ,`,`,` where as the 3.2 v6 from the a4 is a tru v6 that has three coil packs on one side, three on another, and two seperate headers, whereas the r only has one header
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Quote Originally Posted by Ih8OEM View Post
    'tis true... the vr6 was designed like that so it could fit in the gti's... v6's were too big and they wanted a bigger engine for more power, hence the VR6
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    I always loved the power band and low end torque of both my previous 12v Vr6's (97 Gti, 93 SLC). I've often contemplated selling the A4 and looking for a MK5 R32.
    I think a properly tuned stage 3 BT for the 2.0T in the A4, along with a stronger clutch, RS4 brakes and differentials, could make an A4 a very fast and lightweight car. Probably not as agile as a B5 S4 with K04's, but still performance numbers could reach those similar to the RS4.
    Jan 01 2008
    Long Island NY
    Quote Originally Posted by deb38 View Post
    Thats not exaggerate now. I know alot about B5 S4's as i am a big fan but most PJ K04 Stage 3's run in the 12's. Then you have some that run in the 11's that have some strong tunes and fueling with good drivers. I have seen some strong Stage 3 run mid 11's but not at full weight. Stage 3+. RS4/6 Hybrid K04 cars and GTXX cars are a different league that i can see running consistent low 11's and 10's. The B7 is really not that heavy for a luxury car my Tiptronic car at the track with 1/4 tank of gas with full interior (no spare) weighed 3650 with me in it (im 250).
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    You could absolutely swap a 2.7tt for our 2.0t. The motor mounts are in the same place so it should fit right in without TOO many modifications. Now you would have to swap your trans along with the engine also but im not to sure if the trans for the 2.7tt will bolt in the stock 2.0t mounting points though.
    May 28 2007
    Northern Virginia
    Quote Originally Posted by gyroscope View Post
    Now thats what I like to hear... I'm thinking of getting a B7 and doing some fun stuff with it
    Aug 31 2007
    Miami
    [QUOTE=gyroscope;3190981]I always loved the power band and low end torque of both my previous 12v Vr6's (97 Gti, 93 SLC). I've often contemplated selling the A4 and looking for a MK5 R32.
    MKV vr6 are the 24 valve motors. They do make better power, but nothing compared to the sound of a 12v motor. The corrado vr6 is sexy IMHO
    IG | @fukn_fafa
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    +1 on the VR6 swap in comparison to the 2.7T. the 2.7 engine is a b*tch to work on and has to be pulled for anything remotely serious. it's a very high maintenance engine if you know what i mean ($$$).
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    vr6 = fwd vs 2.7t = awd, awd > fwd ;)
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Mar 19 2007
    R32=24v VR6=4 Motion=AWD
    Dec 11 2006
    Boston
    Quote Originally Posted by Auditude2.0T View Post
    My stage 3 pump tune ran 11.6. My buddies stage 3 s4 run 11.9 on pump gas. I can name 20 stage 3's that run 11's, off the top of my head. No exaggeration here.
    For those looking to do a swap. I do a VR6 big turbo setup.
    Stage 3+ RS6's
    Jun 02 2008
    But they still sound amazing and sound much better than the 2.0T.
    Jan 18 2005
    North NJ
    2.7t should go right in into a 3.2 b7. The blocks are very similar therefore the mounts should be the same. I've played with the idea now that I'm getting a b7 but I'll wait to hack into it crazy like that :)
    Registered Member One Ring NOGAROB6S4's Avatar
    Aug 12 2008
    san diego
    Sal seemed to have left out that my s4 did not have a fueling kit so it never reached it's full potential. The s4 is more torquey and sounds amazing I think sal's new kit will still be pretty damn fast. We hope....
    VDUB TECH
    Dec 11 2007
    San Diego, CA
    ^^Yup what he said. I know i wont be faster then a fully Stage 3 S4 and i never said that but there is a guy here in SD that has a fully stage 3 so once i get my kit on ill see if he is down to do a few runs and see how it goes...
    FRRG Southern Ring
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    034 put a 2.8 vr6 into a b5. works just grand with a twin scroll gt45r, hehe
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    I would love to have a 2.7T in the B7. I have had a long love affair with the 2.7T. The first Audi I ever drove was a Nogaro B5 S4 with ecu, downpipe, exhaust, and CO's. Then I got my USP. Wasn't satisfied so I test drove 4 B5 S4's but ended up with a B6 S4 because I preferred the interior that much more. But even when I had my USP I often imagined how perfect and 'best of both worlds' it would be if it had a 2.7T. And now that I had 2 B6's with the world's most pathetic cupholders (I'm a coffee drinker) I love the B7 cupholders. Gosh how perfect it would be to have a stage 3 2.7T stuffed into such a nice chassis. [end of daydreaming]
    Side note: my very first instructor for an HPDE had a Nogaro B5 S4. RIP Matt Amon.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Jul 20 2008
    Chicago
    With all the effort, time and expense, you might be better off to buy a used RS4. There's more to an engine swap (of different engine types) than you think. The electronics is a big one. Then you have to upgrade and calibrate the suspension for the 2.7T. And then of course there's the maintenance issue with a twin-turbo V6. Now try to get your insurance adjusted to cover all the $$$$ you just put into it. Finally, as ugly as it is to work on a V8 S4, the 2.7T is going to be a bigger handful if/when something breaks...it does not have a great track record; not bad, but not too good either.
    Active Member Two Rings 2001S4OWNER's Avatar
    Sep 22 2008
    2001 imola s4, 1969 Camaro, 2009 Ford Superduty (tow rig)
    The r32 3.2 and audi's 3.2 in the a4/a6 body is not the same engine. The 3.2 is a narrow "v" design at I believe 10.6 degreee off set. The a4/a6 3.2 is a true v design. The hpa kit will not fit without major modications....
    would be cool though! We just got a few 2009 a6 with the new 3.0t engine (supercharged)
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    The 2.7T engine is propably my favorite among all recent Audis so far...
    So tunable and so nice...I would love having it in my car...
