Results 1 to 13 of 13
    Oct 29 2008
    China
    A couple of questions about B7 2.0T
    I am new here and my car is a 07 B7 2.0T CVT FFW.
    How much torque can the CVT stand? I heard that the chain is made by LUK, which can stand with even over 400nm. Is it correct and accurate?
    Another thing is that I plan to replace my sway bar with H&R front and rear ones. Currently, I am using RS4 rear sway bar and I am not very satisfied with it. What would you guys comment on the H&R sway bar?
    Thank you.
    B7 2.0T - DTM body kit/IC-Chiptuning Stage 1/PSS 9/BBS RX 207 18'/AP 5200/BMC CDA/Supersprint(downpipe)+ABT(rear)/lots of others
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Re: A couple of questions about B7 2.0T
    sent you a PM
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    About the CVT, I don't know how much exactly but I wouldn't do other than basic performance mods with it. The CVTs are VERY pricey to fix and most (or all?) performance mods will void the transmission warranty even if you don't touch the tranny.
    About the sway bars, do you have coils? Because if your still on your stock suspension the sways are too much for the rear springs.
    Oct 29 2008
    China
    Quote Originally Posted by fromGMCtoAUDI View Post
    Thank you. I am currently using PSS9.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    No one is certain about how much the CVT tranny can hold ( You should be fine on any stage II ), but you need to have some sort of suspension work done so that the sway bar can shine.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Oct 29 2008
    China
    Quote Originally Posted by HID View Post
    Thank you. I am planning to get my car upgraded with stage II. Recently, I upgraded my suspension from B12 to PSS9, which is enough for me, I think.
    Oct 29 2008
    China
    Merry Christmas,guys:)
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by vincent0219 View Post
    It's not christmas in the US yet!!
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Three Rings Spiff69's Avatar
    Nov 22 2008
    2021 Ultra Blue SQ5
    Quote Originally Posted by Charlescrs6 View Post
    Technically, I don't think it's Christmas day where he is either.
    At least it's Christmas Eve!
    Happy Christmas, everyone!
    Oh, and on topic - I have a CVT as well. I've done some searching around the forums and it seems that problems with CVT were more prevalent on the B6 than on the B7. Now this may be because the B6's are just older, but there is at least some evidence that the newer ones are a bit beefier. I would certainly appreciate any additional info.
    I know HID has really pushed his!
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    vincent, what dont you like about the rs4 rear sway bar? i heard it was not a good match for a stock suspension (well i guess it might be ok with pss9) and not for a frontrack anyway.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Apr 15 2007
    WNC
    The Rs4 might be fine for stock sport, but I would definitely worry about using it with the non-sline suspension.
    2013 RS5, 2014 Q7
    Oct 29 2008
    China
    Quote Originally Posted by Spiff69 View Post
    Well, we are ahead of the States for about half a day.
    I heard that lots of B6 A4 or A6 (mostly manufactured in 03 or 04) had serious problems with their tranny (CVT) in China. In addition, I was also informed by the dealer that Audi had improved the CVT at the end of 2006. I bought my car at Apr 2007 and heard only one case having problem with CVT (not typical problem and finally audi gave him a new CVT).
    Oct 29 2008
    China
    Quote Originally Posted by RedS-line View Post
    I didn't mean I don't like it. It s good on my car for the last 10000km. As I am heading to race my car with friends in Jinggang Race Track in Beijing, I d like to upgrade it with H&R front and rear sway bars. I ve done some research which indicated that the steering will be more accurate with the H&R sway bars accompanying with PSS9. You guys input and comment is welcome.
