Results 1 to 30 of 30
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Check engine light and it turned out to be the PCV, story follows...
    So I got a check engine light last Saturday and I had no idea what is was. Then when I got done with working on my car from 12pm-3:30am on Saturday (too long I know) then I realized what the symptoms were. When in park the car revs and after about 30 secs of revving sputters badly.
    I drove around with it and in drive it works fine, but got to the Audi dealer today. After running the codes, there ended up being too much revving in idle (which I felt) and 3 out of 4 cylinders were misfiring. They said I should get it fixed relatively soon other wise once the PCV goes completely I will have oil all over my engine bay.
    I got a slightly used one from them that I will install myself this weekend, but if someone wants to recommend the best site to get the PCV fix kit that would be great!
    Cliff notes- if you car is revving while in park and/or sputtering, you might get a check engine light and there's a good chance its the PCV. Bottomline take a half hour and get it checked out.
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Re: Check engine light and it turned out to be the PCV, story follows...
    out of warranty? That sucks. Perfect time to give the bsh one a try.
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by audidrver View Post
    unfortunately yes, I just passed 50k over thanksgiving so I kinda got screwed. And audi quoted me $195 for the part from them which is the updated audi PCV.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    bumping in case anyone has the same issue!
    Jan 24 2007
    Do this test.
    Start your vehicle & let it idle- try to opening the oil filler cap if it is hard to open tell them give yourself new freaking crankcase ventilation valve since there is recall for them.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I'll try that tomorrow, thanks for the tip!
    Nov 12 2007
    Grand Junction, CO
    You can get one off of ECS for like 60$..
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    search for "eurojet pcv fix" and you should find that fix that will permanently resolve the problem and will never have to worry about it again.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by AudiWxGuy View Post
    They have two versions, the "F" and "E" versions for certain vins and range from 50-65. Those are just the updated Audi versions. I'm going to put the used one on and if it breaks I'll get one of those.
    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    I have the exact problem and the car is at the dealership right now. they said they replaced a valve but that didn't fix the issue. Since it was the 24th they closed early and didn't have the time to do more diag
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    The only fail-safe PCV fix is the one from BSH. That is the one I am going for. I think it costs $99 but it will not fail again, the ECS, Eurojet and others have been reported to fail as well even thought they are more resilient than stock.
    Jan 24 2007
    Quote Originally Posted by nsmith12 View Post
    Did you try the test i told you to do??? What was the result from it??? I belive F is the newer version so i would go with F. If i'm correct E is a one before F
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by A4_cabrio View Post
    Let me know if you want any more info, I can give you it to take to let so they know. basically if there are misfires and you have revving or sputtering, you either need a new coilpack or PCV
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Nico View Post
    what's BSH? Can you link me? TIA
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by A4_Joe View Post
    I tried to get off the coil cap previously and yes it was hard to get off and I couldn't do it with my hand. I'll try with some tools sometime this weekend.
    Jan 24 2007
    coil cap or oil cap??
    if it is hard to remove the oil cap while the engine is at idle that mean you need new crankcase ventilation valve. What i would do is go to the dealer tell them you might possibly need CK recall, which is crankcase ventilation valve. The reason why i asked you to test that because that is how we test it at our dealership if they need new crankcase ventilation valve.
    Mar 02 2007
    Sydney, Australia
    Sure they don't have the kit for the A4 on their website yet but if you contact them they will help you out.
    http://www.bshspeedshop.com/store/home.php
    Another Audiziner who has the system installed on his A4 but you don't need the full set up you only need the PCV fix.
    http://www.audizine.com/forum/showth...=BSH+PCV+catch
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I meant oil, and it actually came off pretty easily. I think its the PCV or the hose/seal. I tried both the C version my car came with and the E version which was eventually recalled, both fail to solve this problem. I'm going to order the E version from ECS for 65 and get the eurojet hose, I hope this solves my problem.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    yeah I was searching last night and saw this but I am going to try the things I said above first, then we'll see if I've solved the issue.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    And has anyone experienced the catalytic converter getting so hot it turns bright frickin red? I got worried...
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Well I attempted to replace the PCV with the E version (my 05.5 came with the C version) and it was even worse. I am now on my way to my dealer to get a F version and will report back later today. Hopefully this puts me in the clear.
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    My car has been at the dealership for more than 1 week. I'm driving a pretty slick A3 in the mean time and that works for best since I have family in town and they dont keep my car clean when I drive them in it.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Cool, I'd like to try out an a3.
    So I got the newest PCV Audi makes, the F version and all is well, it works perfectly and only costs $55 bucks at the dealership. Popped it on, cleared the codes/CEL and it runs smooth. YAY
    Jan 24 2007
    didn't i tell you to get the F?? You should have listen to me
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    I had this same issue along with a coilpack, my dealer went by VIN to tell me which I needed and it was F.
    The thing is, it was leaking under the valve, so you couldn't really see it going out the window.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    In my case it turned out to be the crankcase valve. The trick was to reset the throttle body after replacing. That got the engine to run smooth at idle again.
    Oct 19 2008
    South Florida
    When the pcv goes bad does idle become unstable? My rpm's latly have been jumping from 900 to 1100 and sometimes even to 1300 for a second or two, and I recently got a CEL, I just haven't ran the codes yet to see what's going on.
    Current: 2015 Mythos Black S4 6MT P+, Tech Pckg, B&O, Carbon Fiber, ADS, Ziza 6k
    Previous:
    2013 Audi Allroad APR Stage 1
    2011 Phantom Black A4 quattro 2.0t 6MT Sport Package w/Titanium wheels, APR STAGE 2, K&N Typhoon Intake, Custom 3" downpipe,Stratmosphere Short Shifter
    2006 Silver A4 2.0t FWD 6MT APR Stage3, APR exhaust, Carbonio, VMR TP, H&R Springs, DTM front bumper, S4 grill, DTM carbon fiber rear spoiler, podi w/podi boost gauge
    Dec 09 2007
    CX-7 AWD/A4
    Quote Originally Posted by DTMa42.0t View Post
    Yes it will also throw CEL for it. I got a few, the one that came back very quickly was System Lean on Bank 1.
    07 Mazda CX-7 AWD
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by CX-7&A4 View Post
    Yeah there is a late version VIN fix which is the F and the early VIN which is the E and with the E you have to get a new breather hose
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Idle becomes more and more unstable as more pressure is lost. I'm guessing that is most likely your problem especially if it is just happening during idle. My car was revving for no reason and then sputtering, when it gets really bad the car shakes almost violently.
