Results 1 to 21 of 21
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    DV Abnormal fluttering (fixed it)
    Tonight I was driving and noticed my DV started fluttering instead of the normal "pshh", and I'm just concerned what could have caused the change? It sounds pretty cool but its the fact that its not normal is what's concerning me. I was getting the car into boost just to make sure it felt like full boost, and it does. I took a flashlight and looked at the DV as far as I could see and nothing looked wrong, and there are no abnormal noises other than the change in the type of sound the DV makes. Anyone know what this could be ? TIA.
    BTW I have a Bailey Motorsport DV running on APR 1+.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Dec 06 2007
    Re: DV un-normal fluttering
    at part throttle it'll flutter totally normal.
    -Kirk
    BetaAlphaTau Member #58
    Aug 25 2007
    B6 S4
    Ohh ok thanks, I just never noticed the flutter before. Even when I've been on part throttle in the past I've always had a nice full "Pshh" never a flutter so thats what's weird. Owell. Idk what to make of it.
    -Nick
    Dec 06 2007
    if ur using a 710N or something it might be getting old now when u let off the gas after full boost and it delays a couple seconds or flutters that means u have a bad DV
    -Kirk
    Aug 25 2007
    B6 S4
    Ahh f***. Yea it does delay maybe like 1.5sec after letting off the throttle. But literally it came out of nowhere. I wasnt driving hard or anything i'm starting to think maybe the cold air is stiffening it up? Its been in the mid-teens to low 20's here so hopefully its the weather messing with it. I'll see if its still acting the same tomorrow. Thanks for the input though.
    -Nick
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    in normal driving it should not flutter at all and a 1.5 second delay is huuuge does the bailey need to be serviced?
    Dec 06 2007
    nope ur DV's on its way out happened to me started causing a CEL after a while.
    -Kirk
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Yup, on its way out.
    And while you're at it, Check the vacuum lines.
    No sense in replacing something when the lines feeding the whole operation leak.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Fluttering sometimes could be caused by the vacuum line. Do you have a boost gauge??
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Aug 25 2007
    B6 S4
    Nope, no boost guage. IDK about it being serviced, I got it used from someone idk maybe a year ago and its been fine. The 1.5 sec delay isnt exact its just what I was estimating from my memory but yea there def. is some delay I noticed that during driving. I'll try to check the lines and everything if it keeps happening.
    -Nick
    Dec 06 2007
    mine had the issue where i would go full boost and let off the gas and count 1 mississippi and then psh or fluttering so take it out and service it.
    -Kirk
    Dec 13 2006
    02 Audi A4 1.8Tqm, 95 VW Golf
    It happened to me a couple days ago... I was driving home and it was fine, parked in my garage, left the car running, ran inside to grab something and went back out... While driving back to my office it started to flutter... Got to the office, let the car sit for a couple hours, started it back up and no more flutter... weird
    Oct 29 2005
    10speed
    San Francisco, CA
    un-normal = wrong
    abnormal = right
    - Clint
    Dec 06 2007
    ^^didn't u know Clint became a grammar school teacher?
    -Kirk
    Aug 25 2007
    B6 S4
    un-normal = wrong
    abnormal = right
    lol ive been having alot of brain farts lately, i couldnt think of abnormal haha. I think un-normal could be correct considering that "un" means not, but abnormal is just more correct haha.
    -Nick
    Aug 25 2007
    B6 S4
    Re: DV Abnormal fluttering (updated)
    well I now know its the vacuum/boost line that somehow detached itself from my dv, along with the nipple that was part of the top side of the dv. Thanks to oldguy for the help through PMs, I can't do much on my own without a jack or ramps as far as fixing it goes. I think I'm just gonna wait till I get a new belly pan and have my dads shop repair that, and I'll have them try to fix the dv too but I might need a new one if I can't find that damn nipple that sticks off the top of the dv and came off with the hose. I can't even find the loose hose itself.... Well the boost power loss I'm now noticing sucks too... Just ranting I guess. Feel free to chime in.
    -Nick
    Jun 11 2005
    that means compressor surge.
    I'd get tha fixed NOW. Don't wait. And dont' drive it until it's fixed.
    Unless you can completely stay out of boost.
    2003 1.8T
    Jan 10 2007
    VA
    baileys DV can't be serviced, but as i recall it is lifetime warrantied. the shop that sold me mine a few years back told me if it breaks...just bring it back in for a free replacement.
    btw. flutter isn't normal. even at partial throttle, you should hear an instant and clean 'pshh' when releasing the throttle.
    Aug 25 2007
    B6 S4
    yup that's what I used to have, a nice pshh. my problem is just fixing it. I don't have a jack or ramps somewhat because of a fear of those two that was wrongfully put into me. Also partly my dad owning a building that hosts a repair shop that does all our work, but I hate bothering them its time consuming and annoying. I was thinking of just getting some ramps and fixing it myself, or waiting till I get a new belly pan and having the shop do both at once.
    -Nick
    Aug 25 2007
    B6 S4
    ok just fixed it thanks everyone. I think my main problem was finding the hose cuz I didn't know where to look. I found it before on the 4th time looking and pulled it up by the intake, took the old clamp off, took the nipple out and screwed it back onto the top of the dv, then I put a new clamp on the hose and squeezed my hand down by the dv and got it on after a few minutes. Thank god that headache is gone. Everything seems normal now so hopefully it stays that way.
    -Nick
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    I am glad it worked out, nice. Still curious how the nipple came off the top of your DV...
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
