Results 1 to 4 of 4
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    water temp gauge not working, forgot what the cause was. lol
    i know i had this issue before. but now its not moving at all...its stuck on the start up position so on the Cold Side....what sensor do i need to do?? or what is it...is it my thermostat..?? or is it a sensor i can swap out??
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: water temp gauge not working, forgot what the cause was. lol
    Could be either, ECT sensor or thermostat.
    08 S4- Stock SOLD
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I want to say coolant temp sensor. I thought the factory ones were green and were replaced with black ones. It is located in back of engine by firewall kind of under the accordian hose. There is a writeup how to replace it on audiworld. I was looking for it, but cant find it at the moment. Real easy to replace
    I want to say that usually you will get a code if its bad and the CEL light will stay on.
    Well after looking a little more I could have my colors wrong for the Coolant temp sensor. I know that the early model ones were known to be defective, but I dont remember which color that was if it was green or black. lol
    Also MHolme said ect sensor, I found out that is the coolant temp sensor. so I'll just say What ^^^^^ said.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jan 29 2007
    08 S4 00 S4
    MD
    Not hard to replace at all. And it's the lesser of the two evils...
    08 S4- Stock SOLD
