Results 1 to 4 of 4
    Jun 01 2008
    Apopka, FL
    pic/info request
    getting a p0441 after I replaced a faulty green check valve and I'm thinking mabye I put it on backwards since the CEL is describing it as "incorrect flow"
    anyone have a second to snap a pic of the check valve flow arrow comming off the F-hose or tell me if it's(the flow arrow) facing away or twoard the F-hose.
    Thanks.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: pic/info request
    i had the exact same thing, the exact same spot. the check valve is backwards. change it around and clear the code should be good to go.
    Jun 01 2008
    Apopka, FL
    did, done.. hopefully it won't come back.
    thanks.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by blmlozz View Post
    thanks.
    no problem, it drove me nuts for such a long time, it doesn't affect the car how it runs but that stupid code was so annoying. I checked a million things before this super smart guy named Greg @ SSP said your check valve is the wrong way idiot! ... happy holidays.
