Results 1 to 6 of 6
    Veteran Member One Ring AudiOz's Avatar
    May 19 2004
    toyota supra 1986 and audi a4 2003
    LA
    Need help on Temp Meter in odometer
    I have an Audi a4 03 and today the Temp meter in left hand corner, the niddle suddenly stay in C (cold) all the time from work to my home and I live in LA which is today wasn't really cold at all. Can someone help me to fix it? Thanks
    Al
    Jun 08 2008
    Calgary AB Canada
    Re: Need help on Temp Meter in odometer
    did the car heat up?
    May 19 2004
    LA
    The car is not heat up
    May 19 2004
    LA
    I drove the car this morning to work and I temp meter was working for a while and when I accelerate, the needle on the temp gauge followed when I accelerate the car. Is it the sensor?
    Alex
    Mar 27 2005
    The Cold North
    you will need to checkout the green top sensor and maybe the thermostat. there are lots of people in your area that should be able to lend a hand.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 08 2008
    Calgary AB Canada
    thermostat could be stuck open
