Results 1 to 11 of 11
    Jul 12 2008
    audi b6 avant
    Fredericton NB Canada
    mobil 1 ATF syntetic in a tiptronic 5HP19FL
    mobil 1 ATF syntetic in a tiptronic 5HP19FL ?
    A4 2003 Tip, 70 000 miles, i will flush the Torque Converter and change my filtrer.
    right now my trany is banging when it time to put it in reverse and sometime between shifting.
    so, any one use this kind of oil ?
    second question; do the dextron 3 lubricate the frond diff or the transfer case ? or they have there specific oil. if they get there specific oil, is it some 80-90 ? like the rear diff ?
    i will change everything in the same time.
    Form my bad english, read my sign.
    NO, I'm not drunk or stupid. i'm from Canada and my first langage is FRENCH, so don't ask why my english suck so hard !!!!!
    Dec 06 2007
    Re: mobil 1 ATF syntetic in a tiptronic 5HP19FL
    Search there is a Special MOTUL ATF we use and it is proven to work.
    And ur English is FINE
    -Kirk
    BetaAlphaTau Member #58
    Sep 29 2008
    I'm planning on using Amsoil ATF Universal. It is a bit rough going from park to R for me as well, hopefully new ATF will fix that.
    Apr 12 2007
    Milwaukee
    M1 ATF is now certified for Audi
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Try to put the ebrake on before you let go of the brake.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 06 2007
    ^^x2
    -Kirk
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Quote Originally Posted by biketsai View Post
    Yep...especially when parking on an incline.
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Jul 12 2008
    audi b6 avant
    Quote Originally Posted by infernocl View Post
    how do you know that ?
    the audi name is still not on the back of the oil jug ...
    any one can awenser my transfer case / differentiel question ?
    thank guys
    Nov 07 2008
    A4 Avant 1.8 Tip
    Central Indiana
    Quote Originally Posted by rtb98 View Post
    thank guys
    The Mobil 1 site now states that the "new forumla" M1 Synthetic ATF is now suitable for Esso LT 71141 fluid specd transmissions, such as the ZF trans in our Audi's. Now whether you choose to use the M1 versus the Pentosin is entirely up to you.
    http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
    Jul 12 2008
    audi b6 avant
    great ! thank for the link !
    Aug 26 2005
    Pentosin ATF-1 Synthetic, is on the ZF approved synthetic fluids list. (TE-ML 11) I don't see Mobile 1 ATF on the list yet.
    The differential requires:
    "Fill differential and transfer box with gear oil Burmah SAF-AG4 (Audi / VW Oil No. N 052145000,
    Porsche Oil No. 999.917.545.00)."
