Results 1 to 16 of 16
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    installing 034 motorsports RS4 style inlet pipes problems
    Im trying to get them in now and am stuck. Am i supposed to slide the flanged part onto the turbo inlet with the rubber gasket or use a silicone coupler? I've seen ppl do it both ways but Im having trouble sliding it over the inlet. any tips? Ive tried greasing it up but that hasn't really helped I'd hammer it but Im worried about busting shit up.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: installing 034 motorsports RS4 style inlet pipes problems
    take a dremel to the inside of the inlet and keep cheching until it fits properly. I think the silicone couplers they give you are for mating the lower inlet with the upper inlet. if you like you can go online and buy a transition silicone hose, cut off part of the inlet that attaches to the turbo inlet and do it that way. you'll cut down the vibration the inlet is sending to the turbo, reducing your chance of failure.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    keep that rubber o ring, lube it a bit and jiggle it/slide it into place. once u see that its near the screw whole try screwing it in place which would give ti the extra bit to slide in
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by S4 in_lowplaces View Post
    Because turbo inlet pipes vibrate more than a turbo that is spinning at tens of thousand of RPMS, and is attached to a running engine?
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    dang, you think that maybe they would re-design them after all the complaints
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by revhards4 View Post
    We test fit every set now on a 2.7T motor that we have in the shop. You don't need to completely bottom out the pipe on the turbo inlet. You just need it to slide snugly over the turbo inlet, so that the o-ring seals.
    If you have any fitment issues, feel free to give us a call. We're open tomorrow from 9AM-1PM Pacific Time.
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    I had no problems fitting the pipe to the turbo with 034. No lube or anything just slid right on.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    I got it on the pass side after some finagaling but the driver side will not go on. plus the angle is off a bit on the pass side and it wont turn at all in order to line it up. u guys are open on christmas eve? shitty. I'll prob end up getting a coupler for them anyways.
    MITCH
    Feb 09 2006
    Huntington Beach
    Quote Originally Posted by TallaiMan View Post
    I guess i worded it worng. Theres a difference when the turbo it self is vibrating on its own, than when the turbo is vibrating and it also has an inlet attached to it vibrating. Over time i can see it causing issues.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    I think this pic helps clarify whats going on. Pictures are more fun anyway.
    I actually have the GENJDM pipes, which fit without cutting or modification.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    DO NOT USE GREASE!!!!!! Look what Tony's Imported Auto in Manchester, CT did to my turbos.
    Driver side turbo sucked in the grease throwing the compressor wheel off balance causing it to rub against the housing.
    Feb 09 2006
    Huntington Beach
    thats shitty.
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    sunofa bitch guess I have to figure out a way of getting it off and remove the grease. that sucks
    MITCH
    Senior Member Two Rings Romania's Avatar
    Jan 24 2011
    Canton, OH
    I have inlets from VAST and my mechanic is saying they do not have the hook-ups for air lines. Is that a by-pass? Vast is saying just cup-off the air lines?! Seems weird.. What do you guys advise?
    Thanks...
    Veteran Member Three Rings Danza's Avatar
    Jun 28 2010
    you can cap where those lines are on the motor side off IIRC
    -Ian
    Jan 24 2011
    Canton, OH
    a bit lost..
    Accordind to my mechanic, the black hose from 2nd picture conects in the circled tube from 1st picture. Where do I cancel them out, since the VAST Inlet does not have the black hose (2nd picture) ?!
    The car is a 2004 A6 2.7T 6 speed manual.
    1st picture
    2nd picture
