Ok some backgroud first.
This evening I pulled the drivers headlight assembly to replace the washer pump. During the swap it began to snow. I turned on the ignition to put the drivers window up. I knew this was a bad idea as soon as I did it as I recalled posts about people having done this.
Anyhow, I finished the change, put the headlight back in and started the car. I turned the headlights on and they failed to come on (both sides) and immmediately had a left headlight followed by a right headlight fail message. I cycled the lights off then back on several times but they would not come on.
I turned the car off then restarted it. Turning the headlights on did nothing, however I am no longer getting the fail message.
Car is an 04 Avant with stock halogen housings.
Anyone have any input on how to fix this?
