Results 1 to 8 of 8
    Sep 13 2008
    Western Chicago Burbs
    Leaking Differnetial
    So yesterday i was doing some drifting in the snow and everything seemed fine. i park my car in the driveway overnight and today i moved my car into the garage, and on the snow covered ground i see two little goldish brown spots on the ground. it looks like my differential is leaking on the two sides of the diff where the output yolks are. the puddles are not big. i would estimate maybe 2ml leaked total.
    what should i do? get it towed to a mechanic? drive it and see what happens?
    is it possible that something else is leaking? the fluid did have that nasty smell of gear oil.
    The car is a 2002 a4 3.0 quattro tiptronic with 55xxx miles
    damn Audi. i got it in august and so far i have had to replace an axle due to a torn boot, catalytic converter relacement, rear rake pads, and now this alond with my headlight/windshield washers working and its not a bad fuse. Fuck
    Sep 13 2008
    Re: Leaking Differnetial
    bump
    Sep 13 2008
    come on guys
    Sep 13 2008
    bump again
    Dec 19 2007
    York, PA
    is it like at the axel seals or the dif seals?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It could just be some fluid came out of the vent. I'd clean the diff and drive it for a day or 2 and see if it returns.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    I have the same leak. Its coming from the rear output shaft seal. Theres a DIY somewhere. Ill try to find the link.
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    I have to thank A4 Moda for this Clicky Click
    03' 1.8T Tiptronic
    Ziza yellow Fogs
    A6 engine mounts
