Results 1 to 9 of 9
    Aug 24 2005
    Cali
    un-sharp Cutoff beam
    is there a way to adjust or rotate the cutoff shield? There appears to be light leaking out of the lower arc of the cutoff beam on my driver side and the top arc doesn't seem to be as bright. I've aimed the lights up/down/left/right but the beam doesn't get more crisp. The passenger side looks a lot sharper.
    Edit: forgot to add this is for the halogen projector
    Dec 06 2007
    Re: un-sharp Cutoff beam
    mine does the same thing, try bulb positioning.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Yup, it's the bulb.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Aug 26 2005
    The bulb position may be incorrect. If that isn't the problem, the projector can be removed, and the cut off focus adjusted using thin shims on one side or the other side of the cut off sheild to change the distance of the cut of shield from the projector lens. You would need to arrange a bench test setup to operate the lamp on a test stand. The rotation of the cutoff is dependent on the position of the projector as mounted in the headlight housing.
    Aug 24 2005
    Cali
    Thanks. I"ve tried reseating the bulb but I'll try it again. The bulb is a pretty tight fit though.
    Removing the projector sounds like a big task so I'll assume its not as easy as turning a screw to rotate the cutoff plate.
    Aug 26 2005
    Yeah, removing the projector from the housing is difficult the first time, but once the details involved are understood, having struggled with the hardest aspects involved, it's not hard after that.
    To summarize the process, the adjusters need to be positioned for maximum internal clearance, and the fixed mounting point where the servo motor is mounted for remote or auto adjustment of the beam elevation is turned ccw to remove, then the wire clip at the bottom of the internal moving part, is disconnected to allow the projector to clear for removal. I realize pics are needed for this make sense, I can get some pics and post up a DIY for projector removal.
    Aug 26 2005
    Quote Originally Posted by dunggah View Post
    To adjust the rotation of the cut off, the four mounting nuts need to be loosened, to rotate the projector in the direction needed, then the nuts are tightened again. The projector doesn't need to be removed to move the cut off a little bit. The nuts are 5.5 mm IIRC.
    Aug 24 2005
    Cali
    So it turns out it is the bulb positioning. If I don't secure the bulb with the clip, it looks pretty sharp. It seems to get realigned when it gets clipped in. Is it possible to loosen the clip so there's less pressure on the back of the bulb?
    Aug 26 2005
    The problem with that is the beam will flicker and wiggle over bumps if the lamp is not held tightly in the projector. The focus of the cutoff shield image, can be optimized by using thin shim washers (mylar washers) between the projector reflector bowl, and the cut off shield and between the cut off shield and the lens frame. By varying the number of shims used on the forward side vs the reflector side of the cut off shield, the relative position of the cut off shield is focused to a sharp image. I use a bench test setup and a projector screen to do the focusing adjustment, but this requires that the projectors be removed from the housings.
