Results 1 to 27 of 27
Thread: key fob
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    key fob
    when i bought my car it only came with one key so i think its time to get another just in case. my local dealer wants $130 for the key plus $60 for programming. I've heard to check out ebay and skip the $130 dealer cost of the key, and all i can find on ebay are keys with:
    315 MHz
    4D0.837.231.F
    FCC ID: MYT8Z0837231
    ebay link http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
    whereas my key is:
    315 MHz
    8Z0.837.231.F
    All other numbers match up, besides the first 3 characters in the middle set of numbers. Will this ebay key still work for me?
    Veteran Member Three Rings dfwhockey17's Avatar
    Jun 11 2008
    %252704%2520A4%25201.8tq%25206mt%252C%2520%252708%2520F150%2520Limited
    Fort Worth, Texas
    Re: key fob
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: key fob
    Quote Originally Posted by forevraudi View Post
    315 MHz
    4D0.837.231.F
    whereas my key is:
    315 MHz
    8Z0.837.231.F
    thats ezactly where i bought my key. one thing is my dealer didnt want to cut it because the blade wasnt from audi. so i had to buy a tru HAA and have them cut it
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Re: key fob
    Not sure about the keys but you can program it yourself in case you were not aware. I'm not sure if there is a B6 write up but I used the B5 write up and it works perfectly.
    EDIT: Found it
    You will need BOTH of your "switchblade" keys to reprogram one or both of them.
    Take the key you DO NOT want to program and put it in the ignition. Turn it one click forward.
    Close and lock the drivers door with the second key.
    On the second key (the one in the drivers door) press the 'UNLOCK' button ONCE only. The lights will flash on the car, but the doors will remain locked
    With the second key still in the drivers door, unlock then lock the door again.
    Pull the key from the slot and test remote functions.
    Open drivers door, remove key from ignition.
    High speed Ferrari movement...
    Sep 13 2008
    Western Chicago Burbs
    Sep 01 2008
    San Diego, CA
    Re: key fob
    Quote Originally Posted by B6JoeA4 View Post
    Why are some lower key portions more expensive than others? http://www.remotesandkeys.com/Search...s.asp?Cat=3178 i can't find any similarities to their part numbers and mine...
    Sep 01 2008
    San Diego, CA
    Re: key fob
    bump
    Sep 13 2008
    Re: key fob
    i think some are new and some are used
    Sep 01 2008
    San Diego, CA
    Re: key fob
    Quote Originally Posted by Boosted3.0 View Post
    EDIT: Found it
    If i get my blank key simply cut at a locksmith than can i program they key part(not the buttons) to work on my car using this method?
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    Re: key fob
    EDIT: Found it
    for some reason each time I tried this it never worked, and I tried it on 2 different cars, nothing?? Is there anything else?
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    Re: key fob
    i know some locksmiths wont cut our keys because they dont want to mess up the programming or maybe its because they dont want to mess it up
    Sep 01 2008
    San Diego, CA
    Re: key fob
    bump
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: key fob
    im in the same situation butmy dealer told me i have to get the key from AUDI because of the immobilizer(they said 05s are different).
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Re: key fob
    Why not just buy a B7 remote and reprogram it? You'll have a nicer remote and the DIY isn't that hard. You'd just have to find a blank key.
    http://www.audizine.com/forum/showth...hlight=key+fob
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Sep 01 2008
    San Diego, CA
    Re: key fob
    i dont have vag com
    Jun 29 2008
    Re: key fob
    Me either but if you ask if you can hook up with one of the Socal guys then they'll help you out. I'm certain that any one of them will be more than willing to help out.
    -Damon-
    Sep 01 2008
    San Diego, CA
    Re: key fob
    EDIT: Found it
    good idea but the thing is that i've already bought a used key with new blade and chip and im planning on getting it cut today at a local locksmith, but im wondering if i can program the immobilizer myself with the method explained above (or any other method...?)
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Re: key fob
    315 MHz
    4D0.837.231.F
    whereas my key is:
    315 MHz
    8Z0.837.231.F
    I have a extra remote that I can sell the key is cut but you can use your new one. PM me if you like.
    Jul 27 2008
    Miami, FL
    Re: key fob
    Yes it programs the remote to lock and unlock all doors and truck and arm the alarm...obviously. The dealer told me my remote was broken and it would be 300 for a new remote and 150 to program it. I bought a battery for $2 and programed my "broken" remote and it works amazing.
    Sep 01 2008
    San Diego, CA
    Re: key fob
    i just got my key cut and it functions, only problem is that when i use it to start and drive the car the emergency lights flash as if i stole the car. that's the immobilizer chip that i speak of, how do you program that?
    Sep 01 2008
    San Diego, CA
    Re: key fob
    i haven't been quoted anything cheaper than $130 at my local dealerships so far to just program the already cut key that i have. i almost got into an argument with one of the women i spoke too. is this way overpriced or what?
    Jun 29 2008
    Re: key fob
    That seems a bit high. I'd check with other dealers.
    -Damon-
    Sep 01 2008
    San Diego, CA
    Re: key fob
    Yea it was high. i just got quoted $65 from a different dealer, but that seems high too
    Active Member Two Rings Funkychriscoldm's Avatar
    Oct 28 2008
    03 B6 Silver A/T
    Ogden, UT
    Re: key fob
    You dont need two keys to reset your key fob.. I just reset mine today... page 53 in your owners manual
    Keep it funky!
    Sep 01 2008
    San Diego, CA
    Re: key fob
    im talking about the upper portion. the immobilizer chip inside the keyblade portion
    Oct 28 2008
    03 B6 Silver A/T
    Ogden, UT
    Re: key fob
    Oh my bad guy, and ya that is overpriced just to reprogram a key...Just go make a friend at the Audi dealership and have him hook you up!
    Keep it funky!
    Jun 08 2008
    Calgary AB Canada
    Re: key fob
    Quote Originally Posted by ziggituning View Post
    this is only to get the remote functions working. you need to get the immobilizer programmed at the dealer from what ive heard
