Page 1 of 4 123 ... LastLast
Results 1 to 40 of 156
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    VF RS4 supercharger
    I was at VF last week and took a few pics of the progress of the RS4 supercharger development. My first interest was the fit around the fuel pumps and lines and what needed to be moved. It appears the answer is: nothing is moved. The stock intake is also unchanged, just requiring a custom connection pipe from throttle body to s/c input. The Eaton M90 blows up through a water/air intercooler into the intake manifold. The water reservoir for the intercooler will be hidden away behind the driver side wheel with a cooling radiator up front. The manifold shown is from the S4 and is not the one to be used for the RS, a narrower cleaner looking version has been designed. This leads to the height of this set up, which will require a custom modified hood with a power bulge pressed into a stock Aluminium hood. This is included in the kit too.
    I'm told that as you are reading this, the parts will all be ready and the final assembly will be in progress for the first fire-up.
    At the risk of repeating more things you may already know, it'll set you back $16k for the kit, approx $2k for installation and will be installed and supported directly by VF. It should get you 550hp and the mild boost will not require reducing the stock compression from 12.5:1, also the stock exhaust will be retained. That peak power figure doesn't reveal the huge torque from low down in the rev range from this type of s/c though.
    Thanks obviously to Nik and Sean for encouraging my interest and picture taking while I was there on another unrelated mission. I liked what I saw. I was interested in fit and tidiness and on both counts it was looking good. Can't wait to go back to see it running, just like the owner of the car no doubt!
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: VF RS4 supercharger
    damn, for the price of an rs4 + 18k...i'd be looking at another car!
    Mar 20 2004
    90' 964, 95' F355, 63' Coupe DeVille
    GV, CO
    Keep in mind guys the estimate of 550hp is just that, an estimate based on the performance of the same kit on the s4 motor. We'll get some more solid numbers once the development car is up and running in the next few weeks.
    IMO we're going to see some good power on the RS4 as the kit is still making power when I hit redline! So the RS4's higher rev limiter should allow that power to keep climbing.
    Here is my dyno sheet for reference.
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Quote Originally Posted by ngng View Post
    name one? Quite frankly the car should offer z06/GTR/911 like performance and each of those cars cost the same if not more to own or mod up to the level this RS4 should be at not to mention you can get a used low mileage RS at around 45k. Oh and all of that and you own IMO the nicest looking sedan in production today.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by jdmnomore View Post
    for 60-65k there are LOTS of options. don't get me wrong, the RS4 is very sexy, but for that price range I'd be looking at a pcar
    Mar 20 2004
    GV, CO
    I once had a similar thought process. But once you look into how much it will cost you to insure and to maintain my mind was changed quickly. Not to mention you'll be hard pressed to find a pcar that can serve as a daily driver in the same capacity in varying conditions of a supercharged S4/RS4. Now if we are talking about 2nd or 3rd cars instead of a daily driver that changes things.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Todeshandler View Post
    i guess it all depends on the person too
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    m5 baby.
    Registered Member Two Rings
    Nov 01 2008
    BC
    You have to give preference to a car that comes from the factory at a given performance level with a factory warranty. With RS4's going in the $40's now, an upgrade that costs around 40% of that value for parts and labour is most definitely not a good idea, especially considering these cars are still under factory warranty for another year or two at least. No VF warranty is going to be as comprehensive as a factory Audi warranty. I don't care how utilitarian the RS4 is, there has to be some trade-off between value, performance, and utility.
    A $20,000 upgrade that gives another estimated 130 hp (or 95 whp) is asinine in my opinion. Value vs. performance vs. utility just does not compute!
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    but then you would have a pcar, and not a supercharged b7 rs4... eh, different strokes for different folks i guess.
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    16K + 2K install?
    I would rather do Nitrous......
    for almost 20K, it crazy that you only get 130+ hp......
    I would buy a E46 M3 and Stage III HPF turbo kit.
    but still my applaud to VF. very nice work
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Senior Member Two Rings Yupkwondo's Avatar
    May 10 2007
    2003 M5, 2007 RS4, 2017 R8, 2017 RR SVA, 2019 991.2 GT3 RS, 2020 M2CS, 2021 765LT
    Medina, OH`
    I just don't understand the markup over the S4 version. Same concept, same design, no major extra changes. Around 2k more for the hood and RS4 premium sounds more like it.
    I was completely in the market, until I read this. Hopefully VF will reconsider the pricing structure a little. I would even think 12.5k installed would seem somewhat appropriate.
    Ohh well, not trying to start a riot, just expressing my opinion.
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    Isn't any Audi a pcar now that Porsche owns a majority share in VW?
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    http://www.pcar.org/
    you're a weird dude
    Mar 20 2004
    GV, CO
    I think I need to setup a demo day. Once you guys drive a roots blown v8 s4 you'll be hooked and the blown rs4 can only be better
    I'm in SoCal this weekend if you guys wanna do a gtg on Saturday. We could probably do it at VF.
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    if i had the money, i'd do it.
    I dont see myself getting ride of a car i love just to get something faster.
    Senior Member Two Rings S4Berry's Avatar
    Mar 17 2008
    Tejas
    Quote Originally Posted by wankeldude View Post
    X2... In my opinion, unless you have an endless pit of funds, you have to be insane to spend this kind of money for a measly 100 whp. You could drop $5k in an EVO and have a car that would eat the lunch of a VF S4/RS4.
    * 2004 S4 - H&R Coilovers, 19" Bentley Continental GT Splits
    * 2200 lb EVO VIII (500 AWHP)
    Dec 20 2006
    CAN
    so 18K plus taxes and ancillary fees. just a little too rich IMO for what you're getting. i think the price point should be around 12K all-in for most of us RS4 owners to make the plunge and completely void any warranty. best of luck to VF, thanks for investing their time and money into this.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    Quote Originally Posted by CanuckRS4 View Post
    ^^ agreed.. I was really expecting a 12K price tag. 16K starts to get painful. I know everyone has asked the same question, but seriously.. the parts portion of the job is about the same from S4 to RS4. All they have to do is a little more R&D on tuning for the RS4's 2 ECUs, and a hood. $7K more for that?
    VF is really going to have to give everyone some hard facts/details about the 2 kits and why one is so much more expensive than the other.
    Unless of course the hood they are including in the kit is the C/F hood from MTM which costs about $5K alone.
    Dec 11 2006
    Boston
    Quote Originally Posted by sakimano View Post
    you're a weird dude
    pcar, as in Porsche.
    Stage 3+ RS6's
    Jan 03 2007
    Germany
    Quote Originally Posted by KryptoniK View Post
    from a money making perspective, since companies like to make money to stay in business, there are less rs than s4 on the road, so less possible customers for the product. the R&D, however much is required on top of the s4 blower development needs to get figured in somewhere in the products overall cost, and this is going to be an exclusive mod for a low production run car.
    Some people are like Slinkies - not really good for anything, but you still can' t help but smile when you see one tumble down the stairs.
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    IMO guys, 20k for that increase is way to much.
    You can buy an 01 or 02 e46 m3 for 20k now a days.
    HPF Stage 2.5 Kit And you have 650-700rwhp. Now that came out to be only 40k
    If you wanna do more stage 4 kit which is 40k and you have 1000rwhp for as much as the rs4.
    Jan 03 2007
    Germany
    ^^^but now you are talking about a car thats 6 or 7 years older than an rs4, not a sedan, and isn't an audi. it's not about having the most powerful car for the least amout of cash, it's about adding more ponies to an already fantastic car.
    Dec 03 2006
    Kent
    Absolutely agree with the above poster.
    to the OP , more pictures please .. can you email large versions ?
    Thanks
    Mar 13 2008
    Orlando
    Quote Originally Posted by Andyuk911 View Post
    Thanks
    Ditto who cares about a 1000hp M3, congrats youve just turned your BMW into a camaro. However, one thing that i may not have made clear about my opinion is that while i would take a 550 crank RS4 over a GTR M5 911 etc i would not take a 420 crank RS4 and ive been thinking the 18 grand price tag takes all the excitement outve what VF has done b/c MTM has been offering a kit at that price for the longest now.
    May 10 2007
    Medina, OH`
    Quote Originally Posted by meinblaus4 View Post
    I think that is really the question though, how much more is needed to justify this price.
    Last I read from VF is that it is all the exact same base they are starting with. No major component changes on the supercharger or fuel injection system. Both have the intercooler, both have the remote water reservoir...what is the RS4 adding to almost double the price.
    As of right now we have a hood, and if I am reading correctly manifold revision....
    I do realize it is a smaller customer base, with exclusivity...however the R&D in this was and should be covered by the S4. The tuning for FSI and the two ECU's will cost a little more. I'm not saying this should be a "loss leader" product, but offsetting all of the cost in this product, or marking it up because of exclusivity of the RS4 is I believe an error in judgement.
    When it comes down to it, we are not talking a 50k S4 vs. a 100k RS4...when I look at this pricing it seems to be more inline with something you would put on the R8. Maybe that is their motivation, cater to the R8 crowd, and if any RS4 owners opt in at that price so be it.
    Like I have already said, I was very much in the market for this at 10-12k, but 16k+ is going to be too much.
    Lastly, somewhere on the forums when they first talked about the clearance issues, I was the first one to chime in with "power bulge hood" doesn't that count for anything for me
    May 10 2007
    Medina, OH`
    The MTM kit for the RS4/R8 is closer to $50,000.00
    Veteran Member Four Rings 1FastS4.Com's Avatar
    Feb 19 2004
    Tesla Y Performance and Audi TTRS
    1st off you have to own an RS4. 2nd just like I tell my customers this car the
    (RS4) is not for everyone, some like the M3 some like the C63, IS-F and so on. Each car has its own unique style and habits, I am very happy with owning an RS4 and excited about having the blower installed as well. It won't be the fastest or quickest car ever but it will be a ton of fun. My friend that works across the street from me has a HPF STGII M3 and it is sick fast but IMO very scary to drive and to enjoy, also having spent way over $20K and shipped his car back and forth many times back to HPF @ his expense. So to each his own, and before making anymore crazy posts and talking about money Please at least own an RS4 or S4 and have an open mind..... Just remember V8S4 (I think) spent over $40K on his MTM blower on his S4 and he is happy as can be. Thanks Nik............... I hope to see my car soon!!!
    || 2017 Audi RS3 || 2018 Tesla P3 ||
    Jan 25 2006
    A4 2.0T
    MD
    Don't forget guys the M3 has no traction............
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    really this whole issue is.......TO EACH THEIR OWN.
    if you want it....they got a product for your car. its nice to have.
    plain and simple.
    and there will always be faster cars regardless.
    /endthread
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Jun 02 2008
    Quote Originally Posted by deb38 View Post
    that was a joke...
    Jun 02 2008
    Quote Originally Posted by Yupkwondo View Post
    even worse...45,000 EUROs, so about $63,000 usd.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    wow..cant wait to see the finished project...you guys gonna do a nice little highway run between the VF s4 and VF rs4? I would like to see the results. Thumbs up VF.....
    You gotta pay to play. it's one thing owning a evo/m3 with 600hp and an Audi with 500-600hp. All cars are very different beasts, sure the evo will be faster (tin box), m3 super fast (rwd, no traction, interior is shit)...but if you saw any of those cars down the road which one would you stare at first? I think the rs4 would be many answers. The rs4 has such a sweet stance on the road that it's unmistakable going down the road. I personally like m3's and i will eventually own one but the rs4 is just so much practical and the overall package is much better than the m3. The m3 is just performance for me.
    GL with teh install...you better be posting up some vids when it's done
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    May 03 2007
    german
    heaven/hell
    Quote Originally Posted by vtracer20 View Post
    I love audi to death...
    but I would stare at the M3 first, angel eyes is one reason. then RS4.
    Aug 26 2008
    2006 GTI 2.0T FSI
    Anaheim, CA
    Thanks for stopping by Richard.
    -Sean
    May 18 2008
    My pleasure for sure!
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    Quote Originally Posted by 1FastS4.Com View Post
    1fasts4,
    I've always enjoyed your vehicles and your projects. Your taste and style for vehicles is unsurpassed by these nagging fools. The true appreciation can only come from the owner and passengers of the vehicle. Thank you on behalf of the AZ community for taking the plunge into the SC rs4 world and Kudos to VF for producing a highly anticipated sc kit for a fraction of the MTM cost. I look forward to reading your posts and seeing your pics of the white stallion.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    For us middle class people, 20k for a blower that gives a 95awhp increase is way to much
    Jan 03 2007
    Germany
    at ~ $70K new, the rs4 wasn't marketed to the middle class in the first place.
    Dec 11 2006
    Boston
    Your typical RS4 owner is going to have a decent amount of disposable... of course people are going to price their kits accordingly.
    Stage 3+ RS6's
