Results 1 to 10 of 10
    Oct 19 2008
    South Florida
    installed "scratch & ding" podi gauge and pod
    First of all idk why its called "scratch and ding" the unit was perfect! The color matches so well with the rest of the cluster(I ordered the white podi gauge). I just have a few questions, when the car starts shud vacum be between ~17 and ~20? Second question is I can't seem to have the gauge completly flush against the pod, It sticks out slightly and I think its due to the hose and/or power cables, is there a way to adjust it? If I press against the pod it goes in all the way but as soon as I release pressure it goes back out slightly.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: installed "scratch & ding" podi gauge and pod
    are you stock?
    all i have is the DIY intake pipe, and i'm idling at around 20-22 in Hg. my max boost is around 12 psi, but it quickly dips down and holds around 10 psi as long as my foot is down.
    you can get an "L" adapter for your intake tubing, so that it doesn't stick back as far. didn't yours come with one? i think mine did:
    Oct 19 2008
    South Florida
    I'm not stock, my mods include FMIC, apr exhaust, carbonio, apr stage 2 software, ecode tp. I do have the L adapter, but when I screw it in it sits to the right not straight down.
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    I think you'd have to glue the gauge in to keep it from pressing back out. Mine does that too, a little bit.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    The opening of the pod is 52mm in size but due to how quickly/slowly the plastic cools the opening can be just a bit too big or too small.
    If it is too big take a small piece of black electrical tape and stick it on bottom the body of the gauge behind the black bezel.
    Then insert the gauge by twisting it in and the tape will help wedge the gauge into place and hold it there. It will provide enough friction to allow you to adjust the position as well.
    Oct 19 2008
    South Florida
    I ended up glueing the badboy in looks great but I have some super glue on the top of the gauge lol, any1 reccomend anything to take it off? Lol...what about the vacum is the range where I'm at (~17 to ~20) normal when I'm idling?
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    uh oh. super glue will eat abs plastic like a horse eats hay. good luck with that. =X
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    for the "L" adapter, grab a little roll of teflon tape from the hardware store. put enough on so that it wraps around the threads at least 1 and a half times. make sure you stretch it around the threads so that it's tight. you can put a little more than 1 1/2 rotations, but then it gets harder to thread. make sure that the inlet hole isn't blocked by extra tape.
    it will be tight enough that you don't have to thread the fitting on all the way, and you can set it up so that it goes straight down.
    use the rest of the teflon tape around the house. fix some leaky faucets or shower heads.
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    Pictures of your setup would be greatly appreciated!
    Oct 19 2008
    South Florida
    Ill take them tonight when I get home from work. No1 has any feedback on my vacume pressure? Is it normal?
