Results 1 to 7 of 7
    Senior Member Two Rings joeS407's Avatar
    Dec 20 2007
    2000(B5) S4 Hibiscus red
    naperville
    5 Cylender block
    Hay
    i was just wondering if anyone has a 5 cylender block ( no pistons, connecting rods or anything) they would like to get rid of im looking for one for a project.
    joe
    Veteran Member Three Rings BING's Avatar
    Sep 18 2006
    01' A4 2.8QM ,99' A8Q,93' //S4
    comin up fast on your left !
    Re: 5 Cylender block
    Be more specific..What r u looking to build? Not all 5 cyl. blocks are the same....
    03' VW TDI in GTI clothing
    93' //S4 GT30/40R,VEMS,6MT(sold)
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    02.5' VW Passat Wagon 1.8t
    110 valves =;^)
    Dec 20 2007
    naperville
    Quote Originally Posted by BING View Post
    a 5 cylinder turbo build in the neighbor hood of 800+ hp goin for over 1000
    Sep 18 2006
    Do you have deep pockets?? Have you compiled a list of things you will need to reach 800+ hp?
    AAN or 3B block is what u need, its set up with the oil and water lines for the turbo, dual knock sensors, and ports for water manifold.....As I stated before, HP=$$$ , how much HP u want is proportional to what you can afford......Call Chris Semple at Force5 , he has an AAN bottom end, cuz i bought the head off of it...
    I have a thread on here called"my S4 is back together", on there is a almost complete list of what i have put into the car to get it to about 450 CHP....
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    110 valves =;^)
    Account Terminated Four Rings
    Feb 18 2008
    A4 Avant 1.8TQM
    Downers Grove
    http://car-part.com/cgi-bin/search.cgi
    the first one is your best bet. get a complete engine, till make wiring easier.
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Quote Originally Posted by Koselowiec View Post
    Returned invalid search.
    What parameters did you use to find the AAN or 3B?
    This is a good search engine but engine codes are hard to come by, it seems. Thanks!
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Senior Member Three Rings Audiman78's Avatar
    May 16 2005
    Ephrata, PA
    I have an MC2 block that i would be willing to sell. Its oversized at 82.5 mm up from 81mm. I had plans for it but i changed my mind on what i want. Make me an offer.
