Results 1 to 4 of 4
    May 06 2007
    Rockin' with Audi
    Help please: Does DV makes krraah sound?
    Reference to this thread:
    http://www.audizine.com/forum/showthread.php?t=253149
    1) I get a "krraah" sound when I lift off the gas pedal. Not all the time, usually if I step on it enthusiastically and lift off suddenly. Apparently I'm not the only one.
    2) I figure it's the Divertor Valve or something related. What does the OEM DV sound like?
    3) Will changing to the AWE or Forge DV change the sound at all?
    4) I am using OEM DV
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: Help please: Does DV makes krraah sound?
    Mine doesn't, but this thing does:
    Established Member Two Rings kuwaiti's Avatar
    Dec 13 2008
    Kuala Lumpur
    I get that on mine too. And they get pretty loud and raw when I release the gas pedal (between 60 to 100km/h). Definitely doesn't sound anything like the "hiss" of a BOV (sounds more like when you are clearing your throat in the morning). The "kraahhkh" will not be obvious when going on very high speed (above 130km/h). I got the Forge DV and Carbonio intake, they help in the performance in the car but not the "krah" thing.
    Registered Member Two Rings
    Nov 02 2008
    08 A4 2.T S-line Titanium
    Eden Prairie, MN
    I replaced my stock one with the awe DV and I do a "Krraah" sound when I lift off the gas. It is very minimal. If I had an intake that sound would be louder.
