Results 1 to 9 of 9
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    AEB Head cheap anyone interested
    I have my old AEB head sitting here since I took it out of my car after the melting problem occured.
    Anyway if you dont know, I had a problem where cylinder #1 melted away causing me to blow the head gasket and warp my valves and have some erosion between the exhaust valves, so I got another head and built it instead of having this one welded up and repaired.
    If someone is interested in buying it to have it fixed you can have it for $60
    It will come empty (no valves), but it will have all the lifters and cam caps and if you want I will give you the stock cam gear and a pair of stock cams as well if you want them. It will make shipping costs go up though due to weight, so your call.
    I took pics of each of the cylinder domes so you can kinda see between the exhaust valves in cylinder 1, 2 and 3 where there is a little erosion under the edges of the valve seats so the seats will need to be pulled out and a little welding and shaping done then new seats put in and then on cylinder 1 the one spot will need to be welded and then the head be resurfaced.
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4 (this one is perfect)
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Re: AEB Head cheap anyone interested
    how can the chunk missing out of the head in picture one be fixed ? I dont think u can weld that to fix it
    Apr 24 2005
    E55 AMG, CTS-V
    A head/machine shop would weld in new pure aluminum into the spot missing and then grind it down and put it on the resurfacing machine to make the whole thing flat.
    ~David~
    CTS-V 9.6@148
    Dec 05 2008
    i want one but i would have to show them the picture to see if they can do it.
    I wont b able to do that until next week i was just wondering what all it would take to fix that
    The valve seats are not machined into the head they are an actual separate piece ?
    Apr 24 2005
    E55 AMG, CTS-V
    I had a little welding done around the water jacket on my new head before resurfacing. They charged me $45 for misc. welding and then $29 to resurface the head. That head pictured would need a little more though.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    figured I would bump this in case anyone missed it.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Hmmm. Any idea how much shipping this to DC would cost? A big-port head would be nice!
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Apr 24 2005
    E55 AMG, CTS-V
    It was like $65 shipped from Texas to the Florida Keys originally with it all complete (cams, lifters, valves).
    Probably around $40-50 from here in Jacksonville. I think I might have some stock exhaust valves that are good too, would have to check.
    ~David~
    CTS-V 9.6@148
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    David... classifieds... use them.
    Greg - Moderator
    WWW.ACTLSUB9.COM
