Results 1 to 12 of 12
Thread: Gear Oil
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    Gear Oil
    I am installing the stage three south bend today and decided to change my gear oil what brand oil and grade oil should I use on a 2000 A4 1.8T 160 miles on the clock thanks guys.
    Dec 19 2007
    1988 Mercedes 300E, 2008 Triumph Speed Triple
    Colonie NY
    Re: Gear Oil
    Tranny or Diff?
    Auto/ Manual?
    May 22 2008
    St Clair Shores, MI
    Re: Gear Oil
    Quote Originally Posted by BADB5A4 View Post
    Tranny or Diff?
    Auto/ Manual?
    Tranny and Diff take the same. Auto or manual? He is putting in a clutch, unless SB has a stg 3 torque converter?............
    Search is your friend
    75W90 full synthetic
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Dec 19 2007
    Colonie NY
    Re: Gear Oil
    Oops missed the first part..manual it is then
    http://www.audiforums.com/forum/showthread.php?t=18729
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Gear Oil
    You should be using either a synchromesh or a GL4 rated gear oil 75/90 or 80/90.
    I believe I used the Mobil 75W90, but that's GL5 rated, I don't know if it will cause any long term issues or not. I did some research and my understanding is that GL5 has better lubricating properties than GL4, and Mobil claims their Syn 75W90 exceeds all GL ratings.
    I'm going to use a different brand next time and see if I notice a difference.
    and FWIW, I get the stupid hard shift into 2nd on days below 20*F.
    Dec 14 2006
    Halifax, NS, Canada
    Re: Gear Oil
    GL5 will eat brass which is what your syncromesh is. GL5 is fine for rear diff but the front tranny needs GL4. Redline MTL90 and RoyalPurple make a synthetic GL4 75w-90.
    DJwimbo i would get that out of your tranny and put in GL4.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: Gear Oil
    Quote Originally Posted by Squarrl View Post
    Good to know. I'm a little pissed b/c apparently nobody knew that when I asked, but that's how things go right?
    ... now that I'm actually looking I remember doing this before and saying "F- it, GL5 will work just fine.. it has a higher number, it must be better". The underlying theme was that I was on my 20min break from school and grabbed what I thought was right. I guess I'll have to change that soon.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Gear Oil
    I run Motul 300 with a little Redline Shock mixed in.
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Re: Gear Oil
    Not to thread jack, but what does the center dif take? same thing? I'm looking at doing a refill on my tranny and difs.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Dec 14 2006
    Halifax, NS, Canada
    Re: Gear Oil
    Quote Originally Posted by djwimbo View Post
    Yah I know took me a while to find out what GL-4 ment. The maxim bigger number doesn't work on brake fluid either since DOT5 is not for your car as well... but DOT 5.1 is oh why must they confuse us.
    NOW DEAD :(
    Jul 07 2004
    socal
    Re: Gear Oil
    Quote Originally Posted by Spykce View Post
    Center diff is part of the transmission, so what ever you put in the trans will end up in the center diff.
    Aug 06 2008
    Indiana
    Re: Gear Oil
    good to know, thanks!
