Results 1 to 24 of 24
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Driver door control module just died?
    Opened the driver side door this morning and then it would intermittently lock and unlock, the window might work or not, the buttons might light up or not.
    Did a scan and it said no communication with the door control module.
    So did it just die? Or just a loose connector?
    If it is a connector how do I access it?
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    Re: Driver door control module just died?
    you need to remove the door panel to access that control module. also check your connections at the door in the rubber gurney, maybe some wires are crunched in there.
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Jun 11 2005
    Vancouver, BC
    I did remove one side of the rubber gurney but I can't pull it far enough back to see anything.
    The wires are all wrapped up with that black fabric wrap too.
    When I wiggle the harness I see the light at the bottom of the door turn on and off so something is loose.
    I just find it strange it all of a sudden just happened.
    San Francisco, CA
    your best bet then is to remove the door panel to check if any of the connectors to the control module are lose.
    Jun 11 2005
    Vancouver, BC
    Can you hook me up with any diagrams for the procedure kind sir?
    Any idea of 'special' tools are required? I could take it to my friends shop if this isn't a DIY.
    San Francisco, CA
    ygm... no special tools required, it's totally a DIY.
    Jun 11 2005
    Vancouver, BC
    Thanks
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have you checked the harness as it goes through the grommet in the door frame up by the hinges? The wires are very small and they may have been pinched. I know mine are for my driver front door and thus my car never knows if my door is open. Its great since I don't get the annoying chime if the key is in the ignition but annoying since the interior lights don't come on. I also get an intermittent communications code when I scan the car. Sounds similar to your issue.
    some info on my issue:
    http://www.audigeeks.com/forums/inde...20763#msg20763
    -Doug
    Jun 11 2005
    Vancouver, BC
    Thanks Doug.
    I think it is the wiring harness too as when I opened the door to position #2 the door lights up and everything works.
    Close the door and the lights go off and I can hear the locks engage and disengage by itself.
    I was hoping it was a loose connector than broken wires as plugging in the connector would be a quick fix but it made no sense how it would have just came loose.
    I guess I'll try and take the wiring bundle apart and peek inside but you know what the part number was if I needed to replace it? I'm on www.genuineaudiparts.com and am clueless as to what the harness is.
    Jun 11 2005
    Vancouver, BC
    Well I pulled away the big side of the cover on the right instead of the small side on the left I did last night and every thin wire in that harness is snapped in half and the ground is about to go
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by winston@podi.ca View Post
    No worries. I see you just ordered it. cool beans
    -Doug
    Aug 26 2005
    "x1rider" posted a DIY on AW, (and on other forums too?) for replacing the drivers door harness, to fix broken wires at the door jamb where the harness flexes inside the rubber boot.
    Oct 29 2005
    10speed
    San Francisco, CA
    dude my rear door does this
    - Clint
    Jun 11 2005
    Vancouver, BC
    Here is a pic of the stupid harness. Lucky for me I rolled the window up before it completely broke.
    The brown ground wire is 70% cracked and it the next wire to go.
    Apr 12 2007
    Milwaukee
    bundle up the new harness with tape so they won't break again. the older B3 and B4s have the same problem with trunk wiring. B6 trunk wires get pinched with the same design as well so they will break eventually. copper can only elongate ~15% before it permanently deforms and breaks.
    looks like the clip is easy to pinch off, just use flat head and press?
    Jun 11 2005
    Vancouver, BC
    The weird thing is the other half of the bundle is wrapped with the black cloth tape Audi uses to bundle up the wiring. Dunno why they didn't wrap it all up.
    The big side comes off easy as you push in the clips and it pops off.
    Now I don't have a driver side window for a week while the new harness comes in and I'm a bit paranoid to know when the other harnesses might finally snap in half too.
    Apr 30 2007
    ohio
    i had the same thing happen to me. i just soldered in some extentions the the factory wires then heat shrinked and taped up the connections. been working fine now for a few months. by the way pita to get that boot back in.
    Jun 11 2005
    Vancouver, BC
    Ordered the wiring harness for $150 and it took 3 hours to take the door panel apart, snake out the old harness, snake in the new harness and put it all back together.
    Found out when the door panel was off that this wasn't the first time it had been done
    Unless Audi uses silver duct tape during assembly.
    San Francisco, CA
    They do actually, on all doors:
    I'll take it everything working again then?
    Jun 11 2005
    Vancouver, BC
    Well don't I feel like I fool for amking that comment now.
    But I do think the door panel was taken off before as a screw was missing.
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Silver duct tape? Seriously?
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Veteran Member Three Rings the sheriff's Avatar
    Nov 03 2005
    portland, or
    glad I found this thread......I'm actually in the middle of attempting to solder the one broken wire I've got back and see how long that will last. i had hardly any room at all to work. I'm going to tape them all back up with some cloth take and see what happens. A new harness is not in the budget right now.
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    FYI for the next person that stumbles across this thread, there are seven door panel clips on each side that break when you pull the panel off. They're $0.90 ea at the dealer, so pick up 10 per panel (extra) before you start.
    Jun 11 2005
    Vancouver, BC
    I bought a $5 trim removal tool from the auto parts store and it works great popping those clips out without damaging them.
