Results 1 to 9 of 9
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Quick question about clutch
    I searched, i think i found the answer on the other forums, but was just wondering, when it is cold say like tonight (23 degrees) when the car is very cold, the clutch pedal feels really spongy, then once the car is warmed up, back to normal. Was just curious if anyone else had this..
    Also, it seems when i first start the car in the morning and i put it in gear and give it gas, the car just does not want to move, when i let the clutch out and give it gas, it goes forward but almost seems like it wants to die until i push the clutch back in. Its almost like there is not enough umph to get it to move and im giving it a lot of gas..
    Any thoughts??
    Also on cold start, it sounds like trashcans are under my hood vibrating everything then it goes away..
    Thanks in advance...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    Re: Quick question about clutch
    Mine feels like that slightly but it's not particularly noticiable or of concern to me.
    To answer you latter question, sometimes the Parking brake sticks slightly when it's cold which is why you have to push it a little more to break free. But it could just be because the engine is cold in your case.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Feb 25 2008
    Cape May, NJ
    Yeh it was stuck tonight, but the car even rolls forward in the mornings so its not the brake holding it up..
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    I would think to make sure all your fluids are good, and how many miles are on your clutch? maybe its just old age... Maybe spark plugs?
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Feb 25 2008
    Cape May, NJ
    all my fluids are on point, car has 61,000 miles on it. plugs look fine and are gapped properly
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings a408's Avatar
    Nov 06 2008
    Orange County, CA
    Quote Originally Posted by OneBadAudi View Post
    he said how many miles on the clutch, not car. that could be the issue.
    @Boden_AutoHaus
    2021 Merlin Purple RS6 Avant
    2021 Grigio Scuro F8 tributo
    2020 Aston Martin Vantage
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Try this..start the car in gear with ur clutch pressed in but press on the brakes as well
    Not sure if it will help but its worth a try ?
    Feb 25 2008
    Cape May, NJ
    the motor, trans, and clutch all have 61,000 miles, it does not slip at all, just thought it was odd when i noticed it..
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    Bump...tried to move it again this morning on first start up, almost died yet again but she finally started to move..as far as the clutch, didn't do it this morning, but i am going to change the hydraulic fluid in it and bleed it...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
