Results 1 to 7 of 7
Thread: ESP issue?
    Aug 11 2008
    Calgary
    ESP issue?
    Anyone have this issue:
    This only happens when I am in traffic at slow speed. When crawling through traffic, at partial clutch and partial brake, kind of coasting sometimes the ESP light will come on and stay on, which turns the ESP and there is no way to turn the ESP back on without turing the car off. When this happened in the dry, I would turn the car off, turn it back on and clutch start the car while crawling in traffic, so no big deal.
    This has only happened probably 3-5 times in the last 4 months since I have had the car but it just happened the other day and we have lots of snow so driving without the ESP on, although fun at times it isn't the safest with all the snow and ice out.
    Anyone else have this happen to them?
    Feb 26 2008
    b7s4
    Re: ESP issue?
    Quote Originally Posted by beung View Post
    the answer to your question as you describe it is positively 100% no
    Nov 27 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: ESP issue?
    do you have access to a vag com? and personally as soon as it starts snowing i turn the ESP off in my car.. i feel like i have much more control and the movements of the car become more predictable.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    Re: ESP issue?
    There has been some talk about questionable MAF (mass air flow) sensor causing the ESP light to come on.
    The sensor is located on top rear in the intake snorkel.
    It's the connector you need to remove when accessing the air filter.
    It cost about $ 130.00 US online and is very easy to change.
    Do not remove it from the housing, the new one comes installed into the round plastic housing already.
    Mechanical Catalog - 2005 - Audi - S4
    Partnumber: 077133471KX
    Electrical, Powertrain control, Mass air flow sensor, Mass air flow sensor, s4, new
    I changed mine being pro-active and I "think" the car feels more responsive.
    I know it sounds weird but others have claimed it fixed their erratic ESP light issue.
    Re: ESP issue?
    Im not sure if the A4 and the S4 problems with ESP are similar, but it might be some helpfulk information. I know on the A4 the ESP can be triggered by a faulty rear brake sensor. It can be easily tested by having 1 person hit the brakes and another watching the rear tails. If the lights stay on then after you release the brake pedal then thats your problem. Part cost about $10 from the dealer.
    I see you also mentioned snow, have you been doing some drifting in the snow. With the A4 as well if you throw the car off alignment it could trigger the ESP.
    Hope this was useful.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Re: ESP issue?
    If the ESP light is on and you can't trun it off then it's your MAF. It happened to me right after I picked up my car from service, I turned around and they told me it was the MAF.
    Aug 11 2008
    Calgary
    Re: ESP issue?
    It could be the MAF, I guessed it was linked to the ABS or brake system of some sort but I guess the added heat of sitting in traffic could also be causing the sensor to mis-read.
