Just wanted to do a quick oil change and get home for the xmas season.
Wouldn't you know it, I pulled too hard on the oil filter and crushed the son of a gun!
After doing what I could to try and coax the thing off, I noticed something else. A sort of something that led me to stop short and take a photo to get an answer.
As of now I'm going nowhere until I either get some answers/solutions or a tow back to the stealership.
(Had a coil blow and for whatever reason my spares didn't work (too cold?). They replaced it later with one of my spares and fixed the coolant drain plug which was sweating/leaking, flushed the coolant and replaced it with the proper spec (G12). Cost me nearly seven hundred bones.)
I noticed that there seems to be a bolt or plug missing from this spot in the photo. Anyone know what is the solution to my problems (both the oil filter and plug)?
Cheers, and TIA!!
