Results 1 to 11 of 11
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Belltronics Vector FX2 1/4 mile
    Was bored so I decided to go out and try another 1/4 mile run with my friends GTECH type thing (it is a Belltronics Vector FX2). Don't know how accurate they are.
    I ran a 12.55 @ 111.5mph with a 1.80 60ft, wish I could have got a better 60ft but I was off and on the throttle even launching at 5500rpm due to so much wheel spin. So im thinking if I pull a 1.7 60ft im good for a 12.3 1/4.
    This was at 24psi. Curious what would happen with a higher rev limiter, I was shifting at 7000rpm. Think my 3rd gear syncro is screwing up too
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: Belltronics Vector FX2 1/4 mile
    what?
    you're still pushing 24psi????
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Apr 24 2005
    E55 AMG, CTS-V
    I have been running 22psi but I turned it up to 24 which is what I was running all along before the mishaps that one night. I did the runs and it is back down to 22psi now. I logged before doing the runs and was running at 12.1:1 air/fuel through a 2nd and 3rd gear pull.
    I really have no idea for certain what the cause was of the problem before, but the car was running at perfect air/fuel when I just logged before doing the 1/4 run.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Damn, that's quick... did you make a video?
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I guess it wasn't a lean issue.
    Saint Cloud, Fl
    lookin good now get it on paper
    instagram ------------> low_enforcement
    Apr 24 2005
    E55 AMG, CTS-V
    no, all I have is a shitty 2 megapixel point and shoot camera that is like 7 years old. It only takes 4 seconds of video that is good enough quality to see. Need to get a new camera or a video camera.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Really don't know. I was running 25psi when the problems happened. I ran 24psi for awhile everyday before that with no problems, don't know if that 1 extra psi was an issue or not. Also I only had water spraying at the time, dont know if that was an issue either.
    I had good a/f before on logs too when I did it running 24psi so I wasnt worried about running 24 again to do the runs.
    I am gonna upgrade my feed line sometime not to far away though then I guess just run an inline filter and fuel pressure regulator on the firewall.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Looks good...I will have a file for you next month for larger injectors.
    Apr 24 2005
    E55 AMG, CTS-V
    hmm....
    ~David~
    CTS-V 9.6@148
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    nice
