Results 1 to 7 of 7
    Established Member Two Rings max09163's Avatar
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    BRAKE sensor? Please help
    Hey all,
    Being in the midwest right now the temperature is in the single digits.
    When I'm driving occasionally but frequently the BRAKE light flashes and beeps. I know my emergency brake isn't on or stuck - and it seems like every time I take a right turn it always goes off!
    Please help - it is slowly driving me crazy
    [max]
    ---Looking for USP Lower Front--
    Also looking for top of B6 armrest center console (black)
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Re: BRAKE sensor? Please help
    Could be low brake fluid. If its low, just top it off.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    Quote Originally Posted by 9744RR View Post
    Its just the BRAKE light on the dash, not the display - could that still be it?
    [max]
    Sep 01 2005
    If its the orange circle blinking and beeping, then you need new pads. If the red letters "brake" flash on, you may be low on fluid and will need to replace the pads soon.
    2016 A6 3.0T Stock
    Porsche 356 Stock
    Buncha motorcycles
    Memphis, TN
    im just glad you used BRAKE correctly.....
    there are two brake lights... one on your MFA display-it means your pads are low
    the other is a small red dash light that says BRAKE and just means your fluid is low
    APR Stage 2/AWE Intake
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    Quote Originally Posted by Papachristou View Post
    Thanks! Yea I'm talking about the actual BRAKE light, not on the display
    So I can just top off brake fluid, I don't have to bleed the brakes or anything? Can I use any brake fluid?
    [max]
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    But when your brake pads are low, subsequently your fluid could also be low.
    It seems to be like your brake pads (most likely rear ones) are bad. Take a look at your rear pads, I am willing to bet they are almost gone This same thing happened to me
    -Sami-
