Results 1 to 10 of 10
Thread: ignition issues
    Active Member One Ring wooglin4's Avatar
    Apr 16 2008
    Montreal
    ignition issues
    I've had my B6 for just under a year with 50k on it. Ran fine all winter last winter. This year, I am experiencing a prblm w/ the ignition (thought it could be the anti-theft sys at first, but after removing that the prblm persisted).
    I hear a mechanical sound coming from inside the dash somewhere, but apart from that, there seems to be a breach in connection between the ignition and motor as the motor makes no sound or attempt to start. This usually happens in the cold and only 1 in 5 times.
    any thoughts as to why and how to fix?
    thx
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    Re: ignition issues
    There are a bunch of threads about this. Alot of the people find its the starter. I have the same problem, but if I turn the key slow, I can hear a "click" noise from the driverside firewall. I can "jiggle" the key to make it click. After making it click 3-5 times, it starts. I found this http://www.2carpros.com/forum/2005-a...-vt206980.html
    Im going to try this first instead of the starter.
    Established Member Two Rings bigredx24x's Avatar
    Sep 23 2008
    06 25quattro s4, 95 Ford Rgr, 05 sv650
    DC
    Re: ignition issues
    Yeah, do some searching, i had the same problem and they had to replace my starter.
    Good luck.
    Senior Member Two Rings TN2004S4's Avatar
    Jun 18 2008
    B6S4, 07ODYSSEY(KIDS)
    Fairfax, VA
    Re: ignition issues
    It Is Your Starter Bro. Had The Same Problem Several Weeks Ago. Took It To Audi And The Problem Is Fixed. It Gets Worse As The Weather Gets Colder. It Is Definitely Your Starter..
    Jan 24 2008
    West Coast
    Re: ignition issues
    ^ How much?
    I'm going to join the cold start issue club. I figured I'd start with the battery...
    ...or maybe the starter. We'll see.
    Moderator
    Jun 18 2008
    Fairfax, VA
    Re: ignition issues
    Quote Originally Posted by socals4avant View Post
    ^ How Much?
    I'm Going To Join The Cold Start Issue Club. I Figured I'd Start With The Battery...
    ...or Maybe The Starter. We'll See.
    There Are Several Thread Stating The Cost, But Mine Was Covered Under The Cpo Warranty. I'll Look For The Receipt And Repost When I Get Home.
    Apr 16 2008
    Montreal
    Re: ignition issues
    any thoughts as to why the starter has a hard time as the temperature drops?
    thanks guys
    Apr 16 2008
    Montreal
    Re: ignition issues
    Quote Originally Posted by TN2004S4 View Post
    Did you ever find that receipt?
    I took it in to my local shop. They're saying $280-ish for a new starter (but they aren't even certain that's the issue).
    My car only starts, sometimes.
    Dec 08 2008
    Re: ignition issues
    Still haven't fixed mine... It's been fine for the past few weeks. (27-38 degrees, started right up)
    For the past week, it's been acting up again. It's been 45 degrees plus, and it's having the issues.
    Junior Member Two Rings stonedead's Avatar
    Nov 30 2008
    1962 Chevy C30, 1964 Chevy Malibu, 1970 Chevy K5 Blazer, 1977 GMC Jimmy, 1995 Chevy K1500
    Livermore, CA
    Re: ignition issues
    My car had the same problem ended up being the starter.
