    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Podi boost gauge installed pic/vid
    Just thaught I'd share my latest interior mod with my fellow AZs.
    Qustion: When my gauge when off it reads just under 0. Does this mean that when I peak at at 13 PSI it is actually 14 PSI?
    BEFORE
    AFTER
    AFTER
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: Podi boost gauge installed pic/vid
    what's your idle inHg reading?
    also, what's the max boost you get with your APR 91 flash?
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    The steering wheel looks great. Could you post other pics of your gauge installed?
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    As I posted in the B7 sale thread:
    Every gauge that is sent out is individually checked to make sure it is pointing at zero before it is shipped.
    To date I have not had one gauge not read zero prior to shipping.
    I have had a few clients report that the gauge is not point at zero when they received their order.
    sean18t tells me the needle might move from zero due to elevation changes as the gauges are calibrated from the factory. In his case all of his prior gauges the needle sat above zero while the one he received from me pointed at zero.
    Link -> http://www.audizine.com/forum/showpo...0&postcount=65
    So can the end user adjust it? No you can't.
    You can send the gauge back to me for a replacement but if I get it back and it is pointing at zero then there a replacement I send you will deflect the same.
    If it was somehow damaged in transit I'll send you a replacement.
    Let me know if you have any other questions.
    Nov 12 2007
    Grand Junction, CO
    I don't think elevation is a factor in Toronto.
